I found your offline code a nice idea, so i copy/pasted the code in a YAML-file and saved it in the same folder as where the YAML from @NotoriousBDG is. But than my HA would not start again; after moving the another folder (which does not get included in config), my HA starts again.
if its of any help: thatâs what happens with my posted sensor template tooâŚ
ditched it and looking for @NotoriousBDG installmentâŚ
You can check your config in settings, does this give any errors?
I have named my yaml: offline_alert.yaml
Like I said, I have very little experience in programming and I got it working for my config I just used the template-option in HA to check the templates, and the config checker for any errors in the yaml code
I always run that check, thanks. This time, it ran so long, i gave up waiting and decided to just try it, and if it wouldnât work, just move the yaml out of the way. Which i eventually did. Itâs o.k., maybe i give it another look in the future.
Hey,
I changed your automation for notification using slack to telegram as below, but I only get âLow Battery Levelsâ in the message, no values, any ideas?
- alias: battery_notification_telegram
- platform: time
at: '10:00:00'
- platform: time
at: '18:00:00'
- platform: state
entity_id:
- input_number.battery_alert_threshold_min
- input_number.battery_alert_threshold_max
- condition: template
value_template: *low_battery_check
- service: notify.telegram
data_template:
message: "Low Battery Levels"
- color: '#52c0f2'
title: "These devices have low battery levels"
text: *message
{%- set domains = ['light', 'switch', 'sensor', 'zwave', 'binary_sensor', 'camera'] -%}
{%- for domain in domains -%}
{%- for item in states[domain]
if
(item.attributes.battery_level is defined and
item.attributes['battery_level'] | int < states.input_number.battery_alert.state | int ) -%}
{{ item.name }} below {{states.input_number.battery_alert.state}}: {{item.attributes['battery_level']}}
{%- if not loop.last %}
{% endif -%}
{%- endfor -%}
one step further: how to have it report: None below {{states.input_number.battery_alert.state}}, if none is below the threshold?
{%else%} None gives either as many results as there are items, or no result at all, depending on the place in the templateâŚ
I donât use Telegram, so I canât test this. Can you give this a shot?
- platform: time
at: '10:00:00'
- platform: time
at: '18:00:00'
- platform: state
entity_id:
data_template:
title: "Low Battery Levels"
message: *message
Your code seems to be incomplete so Iâm not including it below. You can accomplish what you want like this.
{% macro battery_level() %}
Your code here
{% endmacro %}
{% if battery_level() | trim != "" %}
{{ battery_level() }}
{% else %}
None
{% endif %}
thank you! this is my first macro⌠nice day it is, learned something new again. Have been looking for ways to create a âmoduleâ like that before, but never new this is the way. Very nice, and so elegant.
btw, indeed missed a final {% endfor %} in the earlier snippet, must have been a cut and paste fluke. This now does the trick:
if
item.attributes['battery_level'] | int < states.input_number.low_lux.state | int ) -%}
{{ item.name }} below {{states.input_number.low_lux.state}}: {{item.attributes['battery_level']}}
{% endif -%}
{%- endfor -%}
{%- endfor -%}
{% endmacro %}
{% else %}
None
{% endif %}
That works, thanks.
If youâve created your battery sensors manually and donât want them to be managed by the package, disable the 3 automations that start with âBattery Sensor fromâ. To delete the sensors that were created, youâll need to clear the retained mqtt topics or reinstall the Mosquito addon.
That being said, my goal was to eliminate the need to manually create any battery sensors. You may have a better experience if you remove the sensors you manually created and let the package manage them for you.
Regarding notifications, those are handled by the automations that start with âBattery Notificationâ.
Check out the latest code on GitHub. It already has each battery on a new line instead of using commas.
What do you mean by before MQTT?
Ah, gotcha. The battery_alert_disabled
attribute doesnât require any sensors to be created via MQTT. Actually, battery_notification
, battery_notification_clear
, battery_notification_slack
, and update_battery_status_group_members
automations donât have a dependency on MQTT.
You can use the package and disable battery_sensor_from_battery_level_attribute
, battery_sensor_from_battery_attribute
, and battery_sensor_from_battery_numeric_attribute
automations to prevent it from creating any sensors with MQTT.
Nope. That works independently from MQTT.
It should be in your main customize section from configuration.yaml, not in the package.
Can you search for sensor.my_iphone_battery_level
on your states page (http://hassio.local:8123/dev-state) and paste a screenshot here so I can see the attributes?
I went through setup using the latest code on github and have some early errors with a config check. Iâm using a fairly fresh 0.74.1 install.
Configuration invalid
Error loading /config/configuration.yaml: while parsing a block mapping
in "/config/packages/battery_alert.yaml", line 174, column 1
expected <block end>, but found '}'
in "/config/packages/battery_alert.yaml", line 499, column 1
I tried commenting out the homeassistant: line, but got additional errors on the first group:.
Am I missing something here?
@pdobrien3, your screenshot shows sensor.dans_ipad_battery_level
, but you mentioned having issues with sensor.my_iphone_battery_level
. Is sensor.dans_ipad_battery_level
the one thatâs giving you trouble?
I wonder if there is a problem with the packages line in your configuration.yaml. Did you use packages: !include_dir_named packages
or something else?
I have that line in the homeassistant: section at the top.
homeassistant:
Could these includes at the end be throwing things off?
### INCLUDES ###
group: !include groups.yaml
script: !include scripts.yaml
EDIT: Line 499 was from a line return due to the copy/paste! I fixed that and four or five others and it loaded up just fine. This has some great new features since I last worked with it. Thanks for all the effort youâve put into this!
Thanks!
@NotoriousBDG. Ok, I have been playing a little bit this am and made some progress.
I changed my configuration.yaml to read packages: !include_dir_named packages
and that seem to make Home Assistant restart quicker as well as reduce the amount of errors I was getting. A couple things:
battery_alert_disabled: true
is still not working forsensor.my_iphone_battery_level
sensors. I tried putting it before thefriendly_name:
in customize and that had no effect. -
sensor.first_floor_siren_battery
will not be recognized by the automations. I solved this by using customize to give the entity a battery icon and it is now showing up. -
andinput_number.battery_alert_threshold_min
cause issues with the lovelace ui. Throws a bunch of error messages. Probably and issue with lovelace but I wanted to bring it to your attention as an FYI.
