Those look like they should all work. I suspect that the missing ones haven’t had a state change since you added the package. Try making each of those sensors change state, and you should see the battery sensor get created.
Which MQTT broker are you using? I suspect there might be an issue with the retain flag with your broker. Personally, I use Mosquitto…
Yes, that’s true for the initial creation of the sensor, but the MQTT retain flag is set to make them persist through reboots.
I use html5 push notifications and a different mqtt discovery topic so I made a few improvements (well i think they are improvements) to your package file.
New MQTT Discovery Topic input text field that sets the appropriate topic.
I couldnt figure out how to default this to ‘homeassistant’ and use the recorder at the same time so on initial load it didn’t pick up any sensors. Once i added my ‘hass’ topic and restarted HA it worked like a charm
New HTML5 notifier name field that sets the notify.NOTIFIER_NAME value
This will default to notify.notify if you dont have a notifier name set
Will also let you target specific devices. If your notifier name is ‘hass’ and your phone is called ‘my_droid’ then entering ‘hass_my_droid’ will push notifications to that device only
Had a spot of trouble clearing some failed nodes from the mqtt discovery. I use Mosquitto running in a docker on my unRAID server. I set channel to clear as “hass/sensor” and could see it being published to Mosquitto in the log. However 0 bytes were sent with it which never seems to trigger mosquittos’s built in save event.
I had to manually stop Mosquitto and Home Assistant dockers. Delete the mosquitto.db file and remove the bad battery nodes from the entities_registry.yaml file in home assistant. Finally that seemed to clean out unknown node and unkown node 2 from HA.
Should I be turning off the automations for Create Batter Sensor from Attributes and Update Battery Status Group Members before doing inclusion on new z-wave nodes?
I updated my Gist with the basic automation for Join. I don’t have it currently setup in my HA instance so I am unable to test. I did trigger it and no errors were found in the log so I assume it works. Hopefully its enough to at least get you started.
Also I’m not sure if you’re a hero or a jerk for introducing my brain to Join. Now it won’t stop thinking of all the things I can use it for to support automation on my Shield TV.
@pdobrien3, @NotoriousBDG
Thanks for explaining that, I am now going to look at my garden irrigation system to see if I can use it there. I like anything that reduces the duplication of code especially in yaml files which seem to grow at absurd speeds!
This realty is one of the great things about HA and some of the people involved. I don’t even have any batteries to monitor yet unless you count our our phones and not only has this project inspired me to push ahead with my plans for door and window sensors but I have learnt something totally unrelated. Actually, two things because I also had the ‘automations-not-always-being-on-after-a-restart’ issue and you have provided a solution/workaround!
Very cool. What you’ve done with the notifier name is really interesting. Now you’ve got me thinking about how that feature can help reduce the sprawl of notification options. I’m definitely going to include this.
I’ll include the discovery topic input text field in the next release too. I can appreciate how helpful that can be.
You’ll need to add at least broker, username, and password options to make it use your Mosquito broker. There is some additional details at MQTT - Home Assistant.
Looks like @jsternadel already posted an example. I’ll incorporate that in the next release.
It should be sending a null payload with retain flag set, so 0 bytes sounds right. It looks like you’ve got an error in the condition of the clear_mqtt_topic automation. Try this instead:
value_template: "{{ '/sensor/' in states.input_text.clear_mqtt_topic.state }}"
I have this error as well. Been getting it for a few revisions (now running a fresh copy) and no battery sensors are being created, but the Battery Alert group/view and all of its things show up.
Are you creating your sensors manually? If so, add
device_class: battery
To each sensor. If you are using MQTT, you are going to have to wait for @NotoriousBDG to chime in. Also, he posted something earlier about clearing your MQTT topics.
I got that error because none of my battery sensors met the conditions of the package. No sensors, nothing to add to the group.
I went into Configuration > Customization and set the device_class to battery for a couple of the Z-wave power-related entities and they showed up in the Battery Status card.
Any reason why this is necessary now? It was really nice before when things just showed up automagically.
Thanks!
EDIT: The ones that are now showing have “0” OR “0.0 W” for values, so I’m thinking those weren’t the correct entities to set the device_class on…
That looks to happen when there are no battery sensors detected. I’ll have to add a condition to the automation to prevent that.
Can you post a screenshot of the states page for the sensors that aren’t working? I need to see the attributes and entity_id for them to troubleshoot the issue.
Device_class would only need to be set on battery sensors that you create manually. Ones that are created automatically will already have it set.
Interesting, there is nothing there that would make me thing it wouldn’t work. Can you try a few things to help isolate where the issue is. First, watch MQTT messages using mosquitto_sub -h MQTT_IP -u MQTT_USERNAME -P 'MQTT_PASSWORD' -v -t 'homeassistant/sensor/#' then force a state change on the multisensor. Let me know if you see any MQTT messages show up. If you don’t see any messages, can you also check to see the last time the “Create Battery Sensor from Attributes” automation was triggered?
