The fantastic power of collaboration Nice work @NotoriousBDG
This is great. Anyway to have a space separating the various entities that are pulled up by the automation in the persistant notification box?
There should already be a comma and space between each item like this Sensor 1 (32), Sensor 2 (30), Sensor 3 (Low)
. What does yours look like?
Here is the screenshot.
works perfectly! Thanks!
Brilliant work thanks to everyone involved. I need to lower the thresholds as I have Xiaomi sensors as well and most of them are shown as low
COuld i just âextendâ this nice automation with device_tracker? Would be nice
@Maaniac, I think i found the issue. The notification was missing commas between domains. Can you try out this updated package below?
@thundergreen, Yes, it shouldnât be difficult to add. If your device_tracker entity has an attribute named battery_level
, youâd only need to add device_tracker to the list of domains. Can you provide more details how your device_tracker entity tracks itâs battery?
## Packages / Battery levels
## Customize
homeassistant:
customize:
## Node Anchors
package.node_anchors:
customize: &customize
package: 'battery_alert'
expose: &expose
<<: *customize
haaska_hidden: false
homebridge_hidden: false
## Group
group.battery_alert:
<<: *customize
friendly_name: "Battery Alert"
icon: mdi:steam
## Automation
automation.battery_alert:
<<: *customize
automation.battery_alert_clear:
<<: *customize
friendly_name: "Battery Alert Clear"
## Group
group:
battery_alert:
control: hidden
entities:
- automation.battery_alert
- automation.battery_alert_clear
## Automation
automation:
- alias: battery_alert
- platform: time
at: '10:00:00'
- platform: time
at: '18:00:00'
condition:
- condition: template
value_template: >
{%- set threshold = 40 -%}
{% macro battery_level() %}
{% set domains = ['light', 'switch', 'sensor', 'zwave', 'lock'] %}
{% for domain in domains -%}
{% for item in states[domain] if ((item.attributes.battery_level is defined and item.attributes['battery_level'] | int < threshold) or ("battery" in item.name | lower and ((item.state | int < threshold and item.state|int != 0) or item.state | lower == "low" or item.state | lower == "unknown"))) -%}
{% if (item.attributes.battery_level is defined and item.attributes['battery_level'] | int < threshold) -%}
{{ item.name }}{% endif -%}
{% if "battery" in item.name | lower and ((item.state | int < threshold and item.state|int != 0) or item.state | lower == "low" or item.state | lower == "unknown") -%}
{% endfor %}
{%- endfor %}
{% endmacro %}
{{ battery_level() |trim != "" }}
- service: persistent_notification.create
data_template:
title: "Low Battery levels"
notification_id: low-battery-alert
message: >
{% macro battery_level(domain) %}
{%- for item in states[domain] if ((item.attributes.battery_level is defined and item.attributes['battery_level'] | int < threshold) or ("battery" in item.name | lower and ((item.state | int < threshold and item.state|int != 0) or item.state | lower == "low" or item.state | lower == "unknown"))) -%}
{{ item.name }} ({{ item.attributes['battery_level'] }}){%- if not loop.last %}, {% endif -%}{%- endif -%}
{%- if "battery" in item.name | lower and ((item.state | int < threshold and item.state|int != 0) or item.state | lower == "low" or item.state | lower == "unknown") -%}
{{ item.name }} ({{ item.state }}){% if not loop.last %}, {% endif %}{% endif -%}
{%- endfor -%}
{% endmacro %}
{%- set domains = ['light', 'switch', 'sensor', 'zwave', 'lock'] -%}
{%- for domain in domains if battery_level(domain) |trim != ""-%}
{{ battery_level(domain) }}{%- if not loop.last %}, {% endif -%}
{%- endfor -%}
- service: notify.slack_notify
data_template:
message: "Low Battery Levels"
- color: '#52c0f2'
title: "These devices have low battery levels"
text: >
{%- endfor -%}
{% endmacro %}
{%- endfor -%}
- alias: battery_alert_clear
- platform: time
minutes: '/30'
seconds: 00
condition:
value_template: >
{% endfor %}
{%- endfor %}
{% endmacro %}
{{ battery_level() |trim == "" }}
- service: persistent_notification.dismiss
Is it possible to create sensors for all battery powered devices? I got a tip about this thread but i used to use Script to track all devices with a battery_level but in that thread the author also indicates that it will not be used when he created a PR because they said use templating. So my question would be how can one still do that? Example output that thread would create:
(in all fairness this template does a better job at finding all battery powered devices) would be sweet to have a similar look too. (its better to get a feeling on battery levels by looking at them every now and then to know when the time is getting close to replace them)
No, this wonât create the template sensors for you, but if you do create them, it should automatically alert on them if entityâs name contains battery.
One thing that could be done is to create a single template sensor similar to @tboyce1âs suggestion in Howto create battery alert without creating a template for every device, but make it include all entities that have betteries instead of just ones that are low. This wouldnât be a clean as your screenshot, but it would give you a single place to look to see current battery status of everything.
Iâll give it a shot, i do like having both options. If i can manage, iâll post it too of course. Have not done much with the templates
Itâs probably possible with either an automation, custom component, or python script that runs every so often and creates/updates template sensors for any sensor that has a battery level attribute. I may play around with this when I have some time if nobody comes up with a better solution before then.
If the custom component from the other thread works for what you want, thereâs really nothing wrong with just keeping it in your custom components for personal use. You could possibly modify it to pick up the same battery levels as the templates.
I tried this and it is great.
Only got one problem.
I have sensors always reporting battery level 0. They donât use battery.
Is there a way to not exclude those sensors? Like, set the minimum value to 1?
@xydix, Try this. I donât have any devices that have 0, so I canât fully test it.
## Customize
homeassistant:
customize:
## Node Anchors
expose: &expose
<<: *customize
## Group
<<: *customize
icon: mdi:steam
## Automation
<<: *customize
<<: *customize
## Group
group:
battery_alert:
control: hidden
entities:
## Automation
automation:
- platform: time
at: '10:00:00'
- platform: time
at: '18:00:00'
condition:
value_template: >
{%- set threshold_high = 40 -%}
{%- set threshold_low = 0 -%}
{% for item in states[domain] if ((item.attributes.battery_level is defined and item.attributes['battery_level'] | int < threshold_high and item.attributes['battery_level'] | int > threshold_low) or ("battery" in item.name | lower and ((item.state | int < threshold_high and item.state | int > threshold_low and item.state|int != 0) or item.state | lower == "low" or item.state | lower == "unknown"))) -%}
{% if (item.attributes.battery_level is defined and item.attributes['battery_level'] | int < threshold_high and item.attributes['battery_level'] | int > threshold_low) -%}
{% if "battery" in item.name | lower and ((item.state | int < threshold_high and item.state | int > threshold_low and item.state|int != 0) or item.state | lower == "low" or item.state | lower == "unknown") -%}
{% endfor %}
{%- endfor %}
{% endmacro %}
data_template:
message: >
{%- for item in states[domain] if ((item.attributes.battery_level is defined and item.attributes['battery_level'] | int < threshold_high and item.attributes['battery_level'] | int > threshold_low) or ("battery" in item.name | lower and ((item.state | int < threshold_high and item.state|int != 0) or item.state | lower == "low" or item.state | lower == "unknown"))) -%}
{%- if "battery" in item.name | lower and ((item.state | int < threshold_high and item.state | int > threshold_low and item.state|int != 0) or item.state | lower == "low" or item.state | lower == "unknown") -%}
{%- endfor -%}
{% endmacro %}
{%- endfor -%}
data_template:
- color: '#52c0f2'
text: >
{%- endfor -%}
{% endmacro %}
{%- endfor -%}
- platform: time
minutes: '/30'
seconds: 00
condition:
value_template: >
{% endfor %}
{%- endfor %}
{% endmacro %}
Thanks.
It solved my problem.
Now it is as expected.
As a Newbie, and not a programmer, I pasted your code where I thought it was ment to be. It off course crashed the Rasp.Pi.
Think I missed this:
ââŚneed to add device_tracker to the list of domainsâ.
How do I do this?
Please advise.
Create a folder under your config directory called packages
. Save the yaml from Howto create battery alert without creating a template for every device as battery_alert.yaml
, then add an include line under the homeassistant:
section of your configuration.yaml. The documentation for packages is available at https://home-assistant.io/docs/configuration/packages/ if you need additional info.
homeassistant:
packages: !include_dir_named packages
To add device_trackers, change every instance of this:
to this:
{% set domains = ['light', 'switch', 'sensor', 'zwave', 'lock', 'device_tracker'] %}
Thanks for you helping out.
I have a Fibaro Water Sensor (Vannsensor) and a Fibaro Smoke Sensor in my setup.
Your code shows this (looks like the Smoke Sensor is not present: Maybe battery level ok? ):
And when running âConfirguration - General - Check Configâ, error is reported:
2017-12-19 22:28:25 INFO (MainThread) [homeassistant.setup] Setting up updater
2017-12-19 22:28:25 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: required key not provided @ data[âactionâ]. Got None
required key not provided @ data[âtriggerâ]. Got None. (See ?, line ?). Please check the docs at https://home-assistant.io/components/automation/
2017-12-19 22:28:26 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: not a valid value for dictionary value @ data[âconditionâ][0][âconditionâ]. Got None
required key not provided @ data[âconditionâ][0][âentity_idâ]. Got None. (See ?, line ?). Please check the docs at https://home-assistant.io/components/automation/
2017-12-19 22:28:26 INFO (MainThread) [homeassistant.setup] Setting up sensor
(Hassio 0.60.0)
Yes, thatâs likely. It should only complain about sensors that have low batteries.
This is complaining about an automation, but without seeing the config and corresponding line numbers itâs hard to say whatâs wrong.
I have deleted the content in the battery_alert.yaml and pasted the code in once again. Still getting errors in the log(?)
My overview displays:
My battery_alert.yaml and error log are attached:
Error log
Yaml
configuration.yaml
