The notifier is setup to my Apple iPhone devices which do not require any special format for the alert content.
Which notifier component are you using? Do you see any errors in the log when the automation fires?
It looks like it is working now. I adjusted the max alert threshold and it now is sending notifications to my iphones.
Iâm not sure why changing the threshold fixed the issue.
Anyway, I appreciate the battery alert piece and will definitely be using it going forward.
Regards
Edit: never mind the below statement. After upgrading, everything is working as before. The Check my Configuration add-on must have triggered on something else. Sorry for causing alarm without proper cause.
Could it be that the package is incompatible with HA 0.87 ? I ran Check My Configuration before updating from 0.86.4 to 0.87, but it says something is wrong here. Maybe this has something to do with this breaking change (but I might be jumping to conclusions :-)):
âMQTT platforms will now flag mistyped configs from configuration.yaml
correctly as invalid, instead of just ignoring them. (@emontnemery - #20562) (mqtt docs ) (breaking change)â
alias: battery_notification_slack
hide_entity: False
initial_state: True
trigger: ?
- platform: time
at: 10:00:00
- platform: time
at: 18:00:00
- platform: state
entity_id: ?
- input_number.battery_alert_threshold_min
- input_number.battery_alert_threshold_max
- action: ?
- data_template: ?
payload: <homeassistant.helpers.template.Template object at 0x7fbeb52b4668>
retain: <homeassistant.helpers.template.Template object at 0x7fbeb52b44a8>
topic: <homeassistant.helpers.template.Template object at 0x7fbeb52b4ac8>
service: mqtt.publish
- data_template: ?
payload: <homeassistant.helpers.template.Template object at 0x7fbeb52acc50>
retain: <homeassistant.helpers.template.Template object at 0x7fbeb52ac5f8>
topic: <homeassistant.helpers.template.Template object at 0x7fbeb52ac160>
- data_template: ?
payload: <homeassistant.helpers.template.Template object at 0x7fbeb529b7f0>
retain: <homeassistant.helpers.template.Template object at 0x7fbeb529b470>
topic: <homeassistant.helpers.template.Template object at 0x7fbeb529bd68>
alias: battery_sensor_from_attributes
condition: ?
- condition: template
value_template: <homeassistant.helpers.template.Template object at 0x7fbeb52ac860>
value_template: <homeassistant.helpers.template.Template object at 0x7fbeb52acc88>
value_template: <homeassistant.helpers.template.Template object at 0x7fbeb52ac4a8>
value_template: <homeassistant.helpers.template.Template object at 0x7fbeb5302da0>
value_template: <homeassistant.helpers.template.Template object at 0x7fbeb52f0f98>
value_template: <homeassistant.helpers.template.Template object at 0x7fbeb529b358>
value_template: <homeassistant.helpers.template.Template object at 0x7fbeb529b828>
value_template: <homeassistant.helpers.template.Template object at 0x7fbeb528d860>
- condition: or
conditions: ?
value_template: <homeassistant.helpers.template.Template object at 0x7fbeb529b278>
value_template: <homeassistant.helpers.template.Template object at 0x7fbeb52acd30>
value_template: <homeassistant.helpers.template.Template object at 0x7fbeb52b4438>
hide_entity: False
initial_state: True
trigger: ?
- platform: event
event_type: state_changed
- action: ?
- data_template: ?
entities: <homeassistant.helpers.template.Template object at 0x7fbeb529c6a0>
object_id: <homeassistant.helpers.template.Template object at 0x7fbeb528d390>
service: group.set
alias: update_battery_status_group_members
hide_entity: False
initial_state: True
trigger: ?
- platform: homeassistant
event: start
- platform: time_pattern
minutes: /5
seconds: 0
- action: ?
- data_template: ?
retain: <homeassistant.helpers.template.Template object at 0x7fbeb52b4cf8>
topic: <homeassistant.helpers.template.Template object at 0x7fbeb52b4f60>
- data_template: ?
retain: <homeassistant.helpers.template.Template object at 0x7fbeb52b4cc0>
topic: <homeassistant.helpers.template.Template object at 0x7fbeb52b4048>
- data_template: ?
retain: <homeassistant.helpers.template.Template object at 0x7fbeb52b4dd8>
topic: <homeassistant.helpers.template.Template object at 0x7fbeb52b4b38>
- data_template: ?
retain: <homeassistant.helpers.template.Template object at 0x7fbeb52b4da0>
topic: <homeassistant.helpers.template.Template object at 0x7fbeb533c240>
alias: delete_battery_sensor
condition: ?
value_template: <homeassistant.helpers.template.Template object at 0x7fbeb52b4710>
hide_entity: False
initial_state: True
trigger: ?
- platform: state
entity_id: ?
- input_text.delete_battery_sensor
Release 1.2.2 is available.
Added
- Alert if battery state is unavailable
Removed
- Removed startup trigger from automation.update_battery_status_group_members
Changed
- Default to notify.notify if input_text.notifier_name doesnât contain ânotify.â
Might be helpful to add a link to the latest release from the original post, as itâs easy to get lost in this huge thread.
I would have long ago if it was possible. That post is not editable anymore.
@NotoriousBDG I have deleted this package, deleted ha database, and deleted mqtt database, recreated clean ha docker container, and still I find those .battery sensorsâŚ
How to completley remove those?
Deleting the package, deleting the MQTT database, then restarting is enough to remove it.
Actualy this works⌠I just forgot I have 2 mqtt servers (cloud and local). After deleting both db, sensors dissapered.
Any idea what mite be causing the following errors?
2019-02-17 21:20:14 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.battery_sensor_from_attributes. Unknown error for call_service at pos 1:
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/automation/__init__.py", line 380, in action
await script_obj.async_run(variables, context)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/script.py", line 131, in async_run
await self._handle_action(action, variables, context)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/script.py", line 210, in _handle_action
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/script.py", line 299, in _async_call_service
context=context
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/service.py", line 76, in async_call_from_config
config[CONF_SERVICE_DATA_TEMPLATE], variables))
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/template.py", line 60, in render_complex
for key, item in value.items()}
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/template.py", line 60, in <dictcomp>
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/template.py", line 61, in render_complex
return value.async_render(variables)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/template.py", line 140, in async_render
return self._compiled.render(kwargs).strip()
File "/srv/homeassistant/lib/python3.5/site-packages/jinja2/environment.py", line 1008, in render
return self.environment.handle_exception(exc_info, True)
File "/srv/homeassistant/lib/python3.5/site-packages/jinja2/environment.py", line 780, in handle_exception
reraise(exc_type, exc_value, tb)
File "/srv/homeassistant/lib/python3.5/site-packages/jinja2/_compat.py", line 37, in reraise
raise value.with_traceback(tb)
File "<template>", line 23, in top-level template code
TypeError: object of type 'NoneType' has no len()
2019-02-17 21:25:22 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.battery_sensor_from_attributes. Unknown error for call_service at pos 1:
context=context
2019-02-17 21:25:53 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.battery_sensor_from_attributes. Unknown error for call_service at pos 1:
context=context
Just deleted the database and restarted HA and get the following error:
2019-02-17 21:52:01 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.update_battery_status_group_members. Invalid data for call_service at pos 1: Entity ID is an invalid entity id for dictionary value @ data['entities']
Interesting. Can you check on your states page for any entities that have a battery_level, battery, or âbattery numericâ attribute with an null value?
The latest version of the package should prevent that from happening on startup, but it may still happen if you have no battery sensors.
I do have one âbattery_level: nullâ on the states page.
I am using the latest version â1.2.2â
Thatâs whatâs causing the issue. Is that a sensor youâd want to be alerted on or would you rather ignore it?
Itâs not needed, It isnât a permanent device, itâs created from google maps device tracker and changes often.
@NotoriousBDG
I discovered the following when the battery one of my Fibaro Smoke Sensor ( FGSD-002 ), went empty, and the smoke sensor lost contact with HA., the HA sensors state became "initializing" and âunknownâ, the battery level attribute was set to 100%.
Meaning, your package battery level sensor displaying 100% for a device which is not connected to HA.
This should be fixed in the 1.2.3 release.
Can you provide some screenshots of the sensor on the states page?
