Now that i look further into it, it seems i never had the components correctly that saved the items after an update. So it was my bad, i can recall a long long time ago i always ‘edited’ it to set in my ios but that can be easilly changed by setting the value which is saved.
That said, i am also looking into cleaning my logs/history more. Might be nice if we could remove the triggers from the log in the battery package it self too. To give an example, this is in my db:
Oh, thanks for letting me know. I’ll make note to fix that in the next release.
AFAIK, that’s not something that can be controlled from within a package. All you should have to do is add the automations to the exclude section of your history config.
Thanks for the info, i was not sure if it was even possible to have history/recorder stuff in a package… now i know that too might be a nice feature in the future (from HA itself that is)
Hi, I have a suggestion. Please look at the last sensor in my screenshot.
Since battery cannot be negative () I think it’s advisable to take the absolute value of the battery reading, so it doesn’t create silly negative values as eCozy smart radiator valves do.
You can use the battery_template feature to do that. See the example below. Just replace sensor.ecozy_entityid with your valve entityid (not the battery sensor entityid). After making the change and restarting Home Assistant, delete the battery sensor and once it gets recreated, it’ll show you the absolute value.
I really love the battery alert thing, but it is giving me a hard time.
I have had a few, very odd duplicate sensors, and some that I wasn’t sure was real, so I deleted them, and waited for them to be recreated.
Some of them has been recreated, a few has not.
Looking through my setup, I can see two IKEA dampers in the bedroom that were added at the same time, one has a battery sensor, the other has not.
An IKEA controller in the kitchen is missing, the damper is there.
In the livingroom the two chained controllers are both missing, though one of them doesn’t even appear in HA.
This one from the bedroom doesn’t have a battery sensor
Not sure if its worth it to anyone but made a few local changes I could submit a pull request for.
Added mqtt discovery topic so you can choose what you want. I can’t spell so i like to abbreviate to “hass”
Notifier name can just be the literal name and no longer needs preceded by “notify”. Its best practice to name all your notify platforms but will still fail over to notify.notify
I added a few more notification integrations. So far I have only tested the HTML5 push notifications since I don’t have telegram, slack, pushover or join setup.
I added all of this to an older version of this package and completely forgot I did that until I upgraded HA and everything broke.
The only one of my battery sensors I can’t figure out is the ups battery sensor. It gets pulled in from the apcupsd component and this package picks it up by (item.name | lower).endswith('_bat'). It reads it just fine but it being a float when everything else is an int annoys me.
Here is what it looks like when i open it up from the battery card:
My customize for that sensor looks like:
sensor.ups_battery:
battery_template: "{{ value_json.value | int }}"
I’ve tried adding `device_class: “battery” but that hasn’t solved anything either. I think it has to do with the sensor itself but I’m running out of ideas. Here is what HA has listed for that sensor:
hello , i have a question. I have tried your package,it is very good. But i have change the name of many of my sensor and now i have old sensor battery i want to delete.I would like to restart from zero.It is possible to delete all the sensor to restart from zero ? not one by one .
How does this work now with .96 that just came out, I haven’t updated yet, but in breaking changes it says it’s going to make battery sensors now automatically
