Thanks. That explains it.
How do i get this project to pick up the IKEA Tradfri remotes battery levels?
The battery entity should get created the next time there is a state change for that sensor. After that, you should start getting alerts for it.
Will this code work out of the box with Hass.io? Or do I need the MosquittoMQTT addon package installed?
Yes, it works with hassio. Yes, you need to install and configure the Mosquitto addon.
I added the MQTT addon, started it and added the below to my configuration.yaml file along with creating a package as described in your instructions. Iâm trying to run the automationâs manually but no state card is showing up. Any advise would be appreciated.
mqtt:
broker: core-mosquitto
discovery: true
discovery_prefix: homeassistant
very cool, thanks for your latest additions!
its getting very very precise though:
Maybe some rounding could be added
Also, all of a sudden i have 3 extra (mqtt) sensors showing up, and state inspector shows i already have them, since it adds _2⌠(theyâre the Unknown ones, the real ones have a valueâŚ)
Is this the discovery: true setting in Mqtt, or your battery alert?
As you can see, the tradfri sensor doesnât show in the battery alert while it has 60% and other batteries have higher levels and are showing.
Ive set the levels between 10 and 80, so the tradfri should show up?
Cheers,
Marius
Is there a way to ignore device trackers? I read through the progression of this project and saw how it was added, but with the newest code, I canât figure out how to remove it. I donât want to get notified every time one of our cell phones are below the threshold.
Thanks.
You canât run the âBattery Sensor fromâŚâ automations manually because they rely on the entity that triggers the automation. Youâll have to trigger a state change on your devices to force the battery sensor to show up (or just wait for the next time the sensor reports in).
Hehe! A new version is below that rounds battery levels to integers.
Those definitely arenât from this package.
Not following. None of those entities have âbatteryâ in its name so they wonât be monitored. Which one represents a battery and how do you know that it represents a battery?
There isnât an easy way to ignore devices by domain. The easiest way now is to create an entry in your customize section for each battery sensor you want to ignore.
homeassistant:
customize:
sensor.sensor_name_to_ignore_battery:
battery_alert_disabled: true
Hereâs the updated package that rounds battery levels.
## Packages / Battery Alert
## 1. Enable MQTT using your preferred MQTT broker
## https://home-assistant.io/components/mqtt/
## 2. Enable MQTT Discovery by adding `discovery: true` and
## `discovery_prefix: homeassistant` under the `mqtt:` section
## of your configuration.yaml
## mqtt:
## discovery: true
## discovery_prefix: homeassistant
## 3. Save this file as CONFIGDIR/packages/battery_alert.yaml
## 4. Add `packages: !include_dir_named packages` under the
## `homeassistant:` section of your configuration.yaml
## homeassistant:
## packages: !include_dir_named packages
## 5. Restart Home Assistant
## 6. Adjust Min Alert Threshold slider to the minimum battery
## level to alert on. Note: the input slider requires the
## recorder component to keep it's state through restarts.
## If recorder is not enabled, the threshold can be set by
## un-remarking `initial` and setting the preferred default.
## 7. Adjust Max Alert Threshold slider to the maximum battery
## 8. To disable alerts for a specific entity, use customize to
## set `battery_alert_disabled` to `true`
## homeassistant:
## customize:
## sensor.sensor_name_to_ignore_battery:
## battery_alert_disabled: true
## Customize
homeassistant:
customize:
## Node Anchors
package.node_anchors:
customize: &customize
package: 'battery_alert'
expose: &expose
<<: *customize
haaska_hidden: false
homebridge_hidden: false
## Group
group.battery_alert:
<<: *customize
friendly_name: "Battery Alert"
icon: mdi:steam
## Automation
automation.battery_notification:
<<: *customize
friendly_name: "Battery Notification"
icon: mdi:comment-alert-outline
automation.battery_notification_clear:
<<: *customize
friendly_name: "Battery Notification Clear"
icon: mdi:comment-remove-outline
automation.battery_alert_slack:
<<: *customize
friendly_name: "Battery Slack Notification"
automation.battery_sensor_from_battery_level_attribute:
<<: *customize
friendly_name: "Battery Sensor from battery_level Attribute"
icon: mdi:battery-alert
automation.battery_sensor_from_battery_attribute:
<<: *customize
friendly_name: "Battery Sensor from battery Attribute"
automation.battery_sensor_from_battery_numeric_attribute:
<<: *customize
friendly_name: "Battery Sensor from battery numeric Attribute"
## Group
group:
battery_alert:
control: hidden
entities:
- input_number.battery_alert_threshold_min
- input_number.battery_alert_threshold_max
- automation.battery_notification
- automation.battery_notification_clear
- automation.battery_alert_slack
- automation.battery_sensor_from_battery_level_attribute
- automation.battery_sensor_from_battery_attribute
- automation.battery_sensor_from_battery_numeric_attribute
## Input Number
input_number:
battery_alert_threshold_max:
name: "Max Alert Threshold"
icon: mdi:arrow-collapse-up
mode: slider
min: -1
max: 100
# initial: 40
battery_alert_threshold_min:
name: "Min Alert Threshold"
icon: mdi:arrow-collapse-down
mode: slider
min: -1
max: 100
# initial: -1
## Automation
automation:
- alias: battery_notification
- platform: time
minutes: '/15'
seconds: 00
- platform: state
entity_id:
- condition: template
value_template: >
{% macro battery_level() %}
{%- for item in states.sensor if (
"battery" in item.name | lower
and not "voltage" in item.name | lower
and not "runtime" in item.name | lower
and not "setpoint" in item.name | lower
and not "charge" in item.name | lower
and not is_state_attr(item.entity_id, 'battery_alert_disabled', true)
) and (
item.state is number
or item.state | length == item.state | int | string | length
or item.state | length == item.state | float | string | length
and item.state | int < states.input_number.battery_alert_threshold_max.state | int
and item.state | int > states.input_number.battery_alert_threshold_min.state | int
or item.state | lower == "low"
or item.state | lower == "unknown"
{{ item.name }} ({{ item.state }}){% if not loop.last %}, {% endif %}
{%- endfor -%}
{% endmacro %}
{{ battery_level() | trim != "" }}
- service: persistent_notification.create
data_template:
title: "Low Battery levels"
notification_id: low-battery-alert
message: >
) and (
{%- endfor -%}
{% endmacro %}
{{ battery_level() }}
- alias: battery_notification_clear
- platform: time
minutes: '/15'
seconds: 00
- platform: state
entity_id:
value_template: >
) and (
{%- endfor -%}
{% endmacro %}
{{ battery_level() | trim == "" }}
- service: persistent_notification.dismiss
- alias: battery_alert_slack
- platform: time
at: '10:00:00'
- platform: time
at: '18:00:00'
value_template: >
) and (
{%- endfor -%}
{% endmacro %}
- service: notify.slack_notify
data_template:
message: "Low Battery Levels"
- color: '#52c0f2'
title: "These devices have low battery levels"
text: >
) and (
{%- endfor -%}
{% endmacro %}
- alias: battery_sensor_from_battery_level_attribute
- platform: event
event_type: state_changed
condition:
value_template: "{{ trigger.event.data is not none }}"
value_template: "{{ trigger.event.data.new_state is not none }}"
value_template: "{{ trigger.event.data.new_state.attributes is not none }}"
value_template: "{{ trigger.event.data.old_state is not none }}"
value_template: "{{ trigger.event.data.new_state.attributes.battery_level is defined }}"
- service: mqtt.publish
data_template:
topic: "homeassistant/sensor/{{ trigger.event.data.new_state.object_id }}_battery/config"
retain: true
payload: >-
"device_class": "sensor",
"name": "{{ trigger.event.data.new_state.name }} Battery",
"state_topic": "homeassistant/sensor/{{ trigger.event.data.new_state.object_id }}_battery/state",
"unit_of_measurement": "%"
data_template:
topic: "homeassistant/sensor/{{ trigger.event.data.new_state.object_id }}_battery/state"
retain: true
payload: "{{ trigger.event.data.new_state.attributes.battery_level | int }}"
- alias: battery_sensor_from_battery_attribute
- platform: event
condition:
value_template: "{{ trigger.event.data.new_state.attributes.battery is defined }}"
data_template:
retain: true
payload: >-
data_template:
retain: true
payload: "{{ trigger.event.data.new_state.attributes.battery | int }}"
- alias: battery_sensor_from_battery_numeric_attribute
- platform: event
condition:
value_template: "{{ trigger.event.data.new_state.attributes['Battery numeric'] is defined }}"
data_template:
retain: true
payload: >-
data_template:
retain: true
payload: "{{ (trigger.event.data.new_state.attributes['Battery numeric'] | int + 1) * 10 }}"
cool, thanks!
they must be created by the mqtt: discovery: true then. Why I canât see just yet, have many more and theyâre un-duplicatedâŚ
Sorry, should have been more specific:
this are hue sensors:
and this is a Tradfri sensor:
Question/wish:
the automation runs every 15 minutes, and one can edit the frequency obviously. It is however very obtrusive if one has several batteries needing attention and this runs timebased as it does.
Could it be an option to only have it trigger if and when a battery needs attention? Waking up today showed 24 notifications waiting for me⌠just one persistent notification would suffice wouldnt it? After which a new lower threshold would kick in maybe.
Maybe the above behavior is caused by the iPhone very quickly depleting because of the HomeAssistant tracking iOS all the more reason to keep activity down a bitâŚ
Not sure if commenting out the trigger
- platform: time
minutes: â/15â
seconds: 00
wonât break the package too much?
Cheers and thanks,!
Marius
Everything was looking good. But after a reboot of ResinOS, I got the "Invalid Config - mgtt " message.
Anything to worry about?
Those are interesting. If I understand correctly, those sensors are battery sensors, but for some reason, they were created without âbatteryâ in their name. That seems to be the same thing that @mcfrojd mentioned above. The way I see it, there are 3 options.
- Get the Tradfri and Hue components updated so battery sensors have battery in their name. This is probably the best solution long term, but out of scope for this discussion.
- Use customize to âfixâ the entity name so that it includes âbatteryâ. Use the updated package below to prevent creating duplicate sensors if you go this route.
- Force a state change for those sensors or just wait. A battery sensor will eventually be created, but it might take a while since battery levels donât change very fast. The problem with this option is that youâll essentially end up with 2 sensors that report the same state.
Options 2 and 3 will work with the updated package below, but I recommend using customize to add âbatteryâ to those sensor names.
That is possible, but Iâm intentionally avoiding that because I donât want to be notified more than twice daily. Iâm ok with persistent notifications updating anytime because those are just shown in the UI. Making it trigger when batteries need attention might cause the notification to come at an inconvenient time.
The persistent notification has a hardcoded id to make sure you only see 1 notification. I donât understand how you are seeing 24 of them. Did you make any modifications to the package? If so, can you post the code youâre using?
I made a change to the persistent notification automation that will prevent calling the persistent_notification.create service if there is already a notification visible with the exact same content.
That would essentially disable the persistent notification.
Finally, hereâs the updated package.
## mqtt:
## discovery: true
## homeassistant:
## homeassistant:
## customize:
## Customize
homeassistant:
customize:
## Node Anchors
expose: &expose
<<: *customize
## Group
<<: *customize
icon: mdi:steam
## Automation
<<: *customize
<<: *customize
<<: *customize
<<: *customize
<<: *customize
<<: *customize
## Group
group:
battery_alert:
control: hidden
entities:
## Input Number
input_number:
mode: slider
min: -1
max: 100
# initial: 40
mode: slider
min: -1
max: 100
# initial: -1
## Automation
automation:
- platform: time
minutes: '/15'
seconds: 00
- platform: state
entity_id:
value_template: >
) and (
{%- endfor -%}
{% endmacro %}
{{ battery_level() | trim != "" and not is_state_attr('persistent_notification.lowbatteryalert', 'message', battery_level()) }}
data_template:
message: >
) and (
{%- endfor -%}
{% endmacro %}
- platform: time
minutes: '/15'
seconds: 00
- platform: state
entity_id:
value_template: >
) and (
{%- endfor -%}
{% endmacro %}
- platform: time
at: '10:00:00'
- platform: time
at: '18:00:00'
value_template: >
) and (
{%- endfor -%}
{% endmacro %}
data_template:
- color: '#52c0f2'
text: >
) and (
{%- endfor -%}
{% endmacro %}
- platform: event
condition:
value_template: "{{ 'battery' not in trigger.event.data.new_state.name | lower }}"
data_template:
retain: true
payload: >-
data_template:
retain: true
- platform: event
condition:
data_template:
retain: true
payload: >-
data_template:
retain: true
- platform: event
condition:
data_template:
retain: true
payload: >-
data_template:
retain: true
Yes, it looks like there might be something wrong with mqtt. Try verifying mqtt is running and check the logs for an errors.
Mqtt not mgtt
HI,
Maybe i should have phrased more carefully, i didnt receive that many persistent notifications in HA frontend, but on my iPhone, every 15 minutesâŚ
they are motion sensors, with an attribute battery, or battery_level, and i have several customized sensors already, even template sensor only showing the battery level of that specific motion sensor: they have 100% so wont show up for a while ⌠ill try and change the other ones too and see if that shows up, thanks for the suggestion!
No, ive copied pasted, your previous last version. Will do so again and report back.
Cheers,
Marius
This package only sends persistent notifications or notifications via Slack. I donât know why those are even showing up on your phone because those donât look like Slack messages.
Actually, they look like battery sensors for the motion sensor to me because the entityâs state matches the battery and battery_level attributes.
You are right.
File â/usr/lib/python3.6/site-packages/hbmqtt/broker.pyâ, line 280, in start
subprotocols=[âmqttâ])
File â/usr/lib/python3.6/site-packages/websockets/server.pyâ, line 356, in serve
server = yield from loop.create_server(factory, host, port, **kwds)
File âuvloop/loop.pyxâ, line 1527, in create_server
File âuvloop/loop.pyxâ, line 1030, in uvloop.loop.Loop._create_server
OSError: [Errno 98] error while attempting to bind on address (â0.0.0.0â, 8080): address in use
The enire log:
https://www.dropbox.com/s/slby03iysrr5fhg/Hassio%20Error%20Log-%20MQTT.txt?dl=0
Update: -Thanks @NotoriousBDG
Its the lates ZigBee - Conbee deCONZ webinterface Add/on, using port 80 and 8080
I use Mosquitto so I donât have any experience with the embedded mqtt broker. That error suggests youâve got something else running on port 8080, which is required by the embedded broker. Either use Mosquitto or move whatever is using port 8080 to another port.
@NotoriousBDG do you have your code in a github repository? Would be easier to see latest code and donât have to scroll through the forum thread to find the latest Updated version of your code.
youâre so unforgiving
Sorry⌠i might have changed notify.slack_notify into notify.notify, since i donât use Slack.
other than that, i wouldnât know. These alerts donât show a title, as your notify automations are programmed to do . Maybe a specific notify.notify syntax would be needed for that, but never mind, ill try and figure that out locallyâŚ
for now im more concerned with the depletion of my iPhones battery which is quite clear following these q5 minute messages. If anything, youâre package proves IOS/HomeAssistant isnât a very economical combination.
