Data are correct, have you tried to delete and recreate the Riemann sum entities?
Yes, on entities page select the “battery power charging” (in column integration should have “template”) then press the gear icon and change the value
This whole thing is diving me crazy. That’s what it looks like after changing the unit to kWh.
I will leave it running for some time and report…
Something is changing… But this can’t be true. I’ll give it some time.
I know… as I said the patience is the key because values takes time to get valid and if there is a bad calculation it will take a day or two to see if the fix worked…
Yes, these values are a bit higher…
I think it is because the values are in kWh instead of Wh. The battery is charging at 2.89 kWh (fronius app) but you entity is that value / 1000.
My suggest is to set the values in Wh and reset the data measured.
You can do it in “Developer Tools” → tab “Services” then select “Utility Meter: reset”.
Add the entities and press “call service”
If works I think that you’ll see it tomorrow
Finally found the solution. The clue was editing the yaml code.
That way didn’t work for me. Even if I still don‘t understand why, I‘m glad it‘s working now!
@crc-error79 thank you so much for your help!
The yaml Code are correct with „W“.
You have to set the Riemann Integration settings to „left“ and „k“ when you create it.
I think I read every post in this topic, and I’m more confused than before.
Can we get one post that combines all configuration steps (included which settings to choose in the Riemann Sum integration)?
Honestly, it’s a huge pain in the a** to read the entire topic and still struggle how to configure this the right way. If we can combine all things together, I will open a pull/feature request to update the documentation for the Fronius integration.
Yes, please!
Is it possible to sum up in a, lets say, understandable was
Thank you!
I’m a total beginner but this is what I got and I think it’s working:
My system:
Inverter 1: Fronius Symo GEN24 10.0 with 28x450W panels.
Inverter 2: Fronius Symo 15.0-3-M with 44x450W
Battery: BYD Premium HVM (three stacks of 19.3) Total storage: 57.96kWh
#Install Riemann sum integral sensor helper
Settings, Devices & services, Add Integration
Integration - Riemann sum integral sensor (helper)
#Create folder with files
Add folder named packages
#Add packages to main YAML Config file:
homeassistant:
packages: !include_dir_named packages
Developer tools, Check Configuration, All YAML Configuration
Add file in packages
fronius.yaml
template:
- sensor:
- name: "Battery Power Charging"
unit_of_measurement: kW
device_class: power
state: "{{ max(0, 0 - states('sensor.solarnet_power_battery') | float(default=0)) }}"
- name: "Battery Power Discharging"
device_class: power
state: "{{ max(0, states('sensor.solarnet_power_battery') | float(default=0)) }}"
- name: "Power Photovoltaics"
unit_of_measurement: W
device_class: power
state: "{{ max(0, states('sensor.solarnet_power_photovoltaics') |float(default=0) + states('sensor.solarnet_power_photovoltaics_2') | float(default=0)) }}"
- platform: integration
source: sensor.battery_power_charging
name: "Total Battery Energy Charged"
unit_prefix: k
method: left
source: sensor.battery_power_discharging
name: "Total Battery Energy Discharged"
unit_prefix: k
method: left
source: sensor.power_photovoltaics
name: "Total Photovoltaics Energy"
unit_prefix: k
method: left
#Add Packages to main YAML Config File
homeassistant:
#Create Helpers
Settings, Devices & services, Click on “Helpers” tab at the top.
Create Helper -
Name: Total Battery Energy Charged
Input Sensor: Battery Power Charging
Integration Method: Left
Precision: 3
Metric: none
Click on helper, Gear Icon
Icon: mdi:battery-arrow-up
Area: Garage
Create Helper -
Name: Total Battery Energy Discharged
Input Sensor: Battery Power Discharging
Precision: 3
Metric: none
Icon: mdi:battery-arrow-down
Area: Garage
Create Helper -
Name: Total Photovoltaics Energy
Input Sensor: Power Photovoltaics Aggregate
Precision: 3
Metric: kilo
Icon: mdi:solar-power-variant
Area: Roof
#Configure Dashboards:
Settings, Dashboards, Energy:
Add Consumption
Consumed Energy: Smart Meter 63A Real energy consumed
Add Return
Energy returned to the grid: Smart Meter 63A Real energy produced
Add Solar Production
Solar Production Energy: Total Photovoltaics Energy
Add Battery System
Energy going in to the battery: Total Battery Energy Charged
Energy coming out of the battery: Total Battery Energy Discharged
I have nearly the same combination.
1x Gen24
1x Symo
1x BYD battery
and I tried your config.
One hint in advance:
I think it should be
Otherwise I can not find a sensor called " Power Photovoltaics Aggregate".
My result:
My config:
Something seems to be wrong… But I have no idea what…
Thank you
Hi Lukas,
I added it as you said at first but already had two sensors with the same name:
I called this one aggregate as it combined the total solar output of the two systems with:
{{ states(‘sensor.solarnet_power_photovoltaics’) |float + states(‘sensor.solarnet_power_photovoltaics_2’) | float(default=0) }}
I recently broke the integration and had to restore from backup, following my notes I was able to get most of it back up. I just need the sun to come up feeding the Photovoltaics sensors and the battery charge sensor to complete the configuration.
I’ll let you know how it goes but everything looks right for me, I have both kW and kWh readings for the PV output and battery charge/discharge working.
Cheers,
Tac
Here is my Aggregate now (no sun):
The Riemann sum helper takes this data and makes the Total Photovoltaics Energy:
Which should only constantly increase, never decrease.
Cheers
Tac
I see an error in your config, you have values returning kkWh, they should be kWh.
Check that in the template fronius.yaml you used (Focus on the unit of measurement):
template:
name: “Battery Power Charging”
name: “Battery Power Discharging”
name: “Power Photovoltaics”
And in the helper you used (focus on the Metric):
Metric: none
Metric: none
Create Helper -
Metric: kilo
Cheers,
Tac
Hey Tac,
I think, I did not get you point…
This is the content of my fronius.yaml:
template:
- sensor:
device_class: power
state: "{{ max(0, 0 - states('sensor.solarnet_leistung_von_der_batterie') | float(default=0)) }}"
device_class: power
state: "{{ max(0, states('sensor.solarnet_leistung_von_der_batterie') | float(default=0)) }}"
device_class: power
state: "{{ max(0, states('sensor.solarnet_pv_leistung') |float(default=0) + states('sensor.solarnet_pv_leistung_2') | float(default=0)) }}"
unit_prefix: k
method: left
unit_prefix: k
method: left
unit_prefix: k
method: left
The Riemann sums are taken over from here:
with my own sensors…
BR,
Lukas
Hi Lukas,
I noticed in your config:
I also had that when I configured my helpers and you have to make sure that when you make the helpers, the only one you change the metric from “none” to “kilo” is the Total Photovoltaics Energy.
Cheers,
Tac
Good morning,
aaah, got it.
I changed this. Now this is the result:
Battery is not discharging now, thats why this entitiy is not available by now.
But, anyway, it does not working:
My house is definitely now consuming 1.9 kWh
And the battery is also not discharging 1.9 kWh
Hm…
Energy vs. Power !
This chart is not showing what your house is currently consuming (kW), but what is has consumed since 0:00 (kWh).
It may be wrong on the first day, since it has no historical data.
Last dump of what I got working. Changed a few names for fewer conflicts with other names.
homeassistant:
fronius.yaml
template:
- sensor:
device_class: power
state: "{{ max(0, 0 - states('sensor.solarnet_power_battery') | float(default=0)) | round(3) }}"
device_class: power
state: "{{ max(0, states('sensor.solarnet_power_battery') | float(default=0)) | round(3) }}"
- name: "Power Photovoltaics Aggregate"
device_class: power
state: "{{ (states('sensor.solarnet_power_photovoltaics') | float(default=0) + states('sensor.solarnet_power_photovoltaics_2') | float(default=0) ) / 1000 | round(3) }}"
name: "Battery Energy Charged Counter"
method: left
name: "Battery Energy Discharged Counter"
method: left
source: sensor.power_photovoltaics_aggregate
name: "Photovoltaics Energy Counter"
method: left
#Create Helpers
Create Helper -
Name: Battery Energy Charged Total
Precision: 3
Metric: none
Area: Garage
Create Helper -
Name: Battery Energy Discharged Total
Precision: 3
Metric: none
Area: Garage
Create Helper -
Name: Photovoltaics Energy Total
Precision: 3
Metric: none
Area: Garage
Add Consumption
Add Return
Solar Production Energy: Photovoltaics Energy Total
Add Battery System
Energy going in to the battery: Battery Energy Charged Total
Energy coming out of the battery: Battery Energy Discharged Total
#TROUBLESHOOTING ONLY!
#Delete/Flush/Purge Broken Entities
Developer Tools, Services (Tab)
Service: recorder.purge_entities
Click the Green “+ Choose entity”
Fill in the entity to be purged
Click “Call Service”
Ctrl-F5 the web session and see if they have been purged (remove from fronius.yaml first before purging for example).
Tac
For anyone having troubles (as I did) getting it to work with adding the templates and sensors in the .yaml files (configuration.yaml or otherwise), I recommend you try it with adding it manually in Settings → Devices & services → Helpers, that way I got it working. See also the attached screenshots.
Guide:
State template: {{ max(0, 0 - states('sensor.solarnet_power_battery') | float(default=0)) }}
, Unit of measurement: W
, Device class: power
, and so on.
