[HowTo] Setting up a Telegram Bot for all your Home Automation messages
If your Telegram Out node (Telegram sender) has the option ‘Track’ enabled, and you wire loops back to previous commands, it should work. To exit the tracking is ending with Out node with ‘Track’ disabled (no node output).
Check my example in my first posting and/or check the configuration topic for more explanation.
