dms
(DANIEL)
April 6, 2022, 4:08pm
22
The plant id is the last 4 or 5 link numbers. Like S-Miles Cloud - Hoymiles Power Electronics Inc. - The plant id is 11111.
The MQTT_host, password and user is used only if you are using an external mqqt server.
If any problem you could send the app log.
The github link is GitHub - dmslabsbr/hoymiles: Hoymiles ADD-ON for Home Assistant
O ID e o certo esta dando este erro .
502: Bad Gateway!
Screenshot_20220406-165519_Home Assistant|243x500
barchab
(Barchab)
September 6, 2022, 4:16pm
26
I also get 502 error and no information is displayed, no entities are visible in the interface etc. On the other hand log files show that s-miles website is properly accessed and login is successful.
I installed home assistant from VM provided on the website.
mikoday
(Mikoday)
April 5, 2023, 6:50pm
27
I have added this to my main configuration, but I don’t know how to add this to the dashboard as I cannot see PV_panel_1 anywhere…
Vinicius, voce descobriu como corrige este erro? estou com o mesmo problema.
