HP Printer Ink Levels
Does the HP printer management tool on Windows show the correct values?
I’m on a Mac but the web interface shows the correct values
Hi, theres a separate thread on this same topic. I found that for certain HP inkjet printers you can’t get to the ink levels via snmp. This may be the case for other models. You can however get to it via specific XML files (which the web interface uses).
Have a look at:
Other Article
Hope that helps.
Thanks! That’s seems to be working fine
Thanks for the starting point, this also worked with my LaserJet M175nw… I also found some additional info like pages printed, pages remaining, drum life, printer status… it took some fooling around to find them so I figured maybe I could save someone else the trouble… thanks guys!
############################## BLACK TONER
  - platform: snmp
    host: 192.168.x.x
    baseoid: 1.3.6.1.2.1.43.11.1.1.9.1.1
    accept_errors: true
    scan_interval: 86400
    unit_of_measurement: '%'
  - platform: snmp
    host: 192.168.x.x
    baseoid: 1.3.6.1.4.1.11.2.3.9.4.2.1.4.1.10.11.1.0
    accept_errors: true
    unit_of_measurement: 'pages printed'
  - platform: snmp
    host: 192.168.x.x
    baseoid: 1.3.6.1.4.1.11.2.3.9.4.2.1.4.1.10.5.1.1.1.0
    accept_errors: true
    unit_of_measurement: 'pages remaining'
############################## CYAN TONER
  - platform: snmp
    host: 192.168.x.x
    baseoid: 1.3.6.1.2.1.43.11.1.1.9.1.2
    accept_errors: true
  - platform: snmp
    host: 192.168.x.x
    baseoid: 1.3.6.1.4.1.11.2.3.9.4.2.1.4.1.10.11.2.0
    accept_errors: true
  - platform: snmp
    host: 192.168.x.x
    baseoid: 1.3.6.1.4.1.11.2.3.9.4.2.1.4.1.10.5.1.1.2.0
    accept_errors: true
############################## MAGENTA TONER
  - platform: snmp
    host: 192.168.x.x
    baseoid: 1.3.6.1.2.1.43.11.1.1.9.1.3
    accept_errors: true
  - platform: snmp
    host: 192.168.x.x
    baseoid: 1.3.6.1.4.1.11.2.3.9.4.2.1.4.1.10.11.3.0
    accept_errors: true
  - platform: snmp
    host: 192.168.x.x
    baseoid: 1.3.6.1.4.1.11.2.3.9.4.2.1.4.1.10.5.1.1.3.0
    accept_errors: true
############################## YELLOW TONER
  - platform: snmp
    host: 192.168.x.x
    baseoid: 1.3.6.1.2.1.43.11.1.1.9.1.4
    accept_errors: true
  - platform: snmp
    host: 192.168.x.x
    baseoid: 1.3.6.1.4.1.11.2.3.9.4.2.1.4.1.10.11.4.0
    accept_errors: true
  - platform: snmp
    host: 192.168.x.x
    baseoid: 1.3.6.1.4.1.11.2.3.9.4.2.1.4.1.10.5.1.1.4.0
    accept_errors: true
############################## IMAGING DRUM
  - platform: snmp
    host: 192.168.x.x
    baseoid: 1.3.6.1.2.1.43.11.1.1.9.1.5
    accept_errors: true
## I didn't get a chance to see what the different states were for the mode/status,
## seems power_mode will tell you if in sleep/awake or low-power mode, etc and
## printer_status_2 will just give a Ready state even when sleeping which seems to
## make more sense.. you will have to see which works best for you..
## I think status_2 will tell you if needs paper etc, but didn't look that far into it yet...
################################## PRINTER
  - platform: snmp
    host: 192.168.x.x
    baseoid: 1.3.6.1.4.1.11.2.4.3.1.2.0
    accept_errors: true
    scan_interval: 300
  - platform: snmp
    host: 192.168.x.x
    baseoid: 1.3.6.1.2.1.43.17.6.1.5.1.2
    accept_errors: true
    scan_interval: 300
  - platform: snmp
    host: 192.168.x.x
    baseoid: 1.3.6.1.4.1.11.2.3.9.1.1.3.0
    accept_errors: true
    scan_interval: 300
  - platform: snmp
    host: 192.168.x.x
    baseoid: 1.3.6.1.2.1.43.10.2.1.4.1.1
    accept_errors: true
    unit_of_measurement: 'pages'
How did you do the nice toner graphic?
What card are you using to create this printer graphics?
Bar-card and vertical-stack-in-card… found it here
