Your only posts on this should be here: https://community.home-assistant.io/t/custom-component-hubitat/. That’s the only place your problem could be. You either have the integration configured wrong, the integration is broken, or there’s something on the hubitat or home assistant side that has changed the way the integration should work. In any case, any and all of those issues would get fixed via modification of the integration.
