Hue light configuration for UI?
A bit different use cases between them
Scene
You can create scenes that capture the states you want certain entities to be. For example, a scene can specify that light A should be turned on and light B should be bright red.
Script
The script component allows users to specify a sequence of actions to be executed by Home Assistant when turned on.
