I ask because the issue could be general issue related to the custom_component
functionality of Home-Assistant, rather than specific to this CC. I don’t have any other advice other than to see if anyone else has this issue
I cannot say for sure if I am having a similar issue or not but probably maybe lol. I’m new to hass (hassbian 0.73.1) and thought this was an important/well documented custom component that would be the first custom component I would try. I get Unable to find component sensor.hue July 11, 2018, 11:58 PM loader.py (ERROR) after following the readme and placing the py file in a custom component folder and adding the lines to my configuration file. I sort of thought it may be related to the way the hue bridge was being implement now so tried numerous times to set it up manually with a phue.conf file but I just cant make it work and have been at it for 6 hours+. All I have been able to achieve is to remove all my hue lights from home assistant. I noticed the token for the hue bridge is now stored in a core_config_entries file now so things seem different than they once were and I think I am getting a little lost. Thanks for any guidance you may have. Looks great when it works though from what I can see of peoples set ups. I think this is definitely important enough to be brought in as a official component . If I can provide any more info pls let me know
with 73.1 doesn’t work?
I am getting the following error in the home-assistant.log when hassio starts:-
‘You are using a custom component for sensor.hue which has not been tested by Home Assistant.’
I am using Home Assistant 0.73.1. Any ideas what the problem is please.
not necessarily a problem, more sort of a disclaimer by the Hassio dev’s. CC’s are not Hassio code, so no responsabilty can be taken by the Hassio developers when things do go wrong.
Hi, i got this error on Home Assistant 0.69.1
2018-07-18 12:39:27 ERROR (MainThread) [homeassistant.config] Invalid config for [sensor.hue]: required key not provided @ data[‘ip_address’]. Got None. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.hue/
maybe i have to create a new key.
yes, after the update to 73.1 the component doesn’t work
it does actually…
but i got 0.69.01
you’re HUE Motion works with 73.01?
Yep, .73.2 even…
… ok. i found my fault.
…i thanks DHCP. change the IP from the HUE
and yes it’s work
hi
where do you place this code?
It goes under sensor. So:
office_motion:
friendly_name: "Movement"
Oh so it’s a sensor template
(I’ve not used that before)
Great work, I’ve got the sensor up and running (and can use it with pure automations), but I just can’t seem to get a python script working. Not even with the exact script posted in the hackster post (using my entity_id’s).
hue_remote_1.py:
button_obj = hass.states.get('sensor.hue_dimmer_1_status')
button = button_obj.state
if button == '1':
hass.services.call('light', 'turn_on', { "entity_id" : 'light.living_room_lightstrip', 'color_name': 'green' })
elif button == '2':
hass.services.call('light', 'turn_on', { "entity_id" : 'light.living_room_lightstrip', 'color_name': 'red' })
elif button == '3':
hass.services.call('light', 'turn_on', { "entity_id" : 'light.living_room_lightstrip', 'color_name': 'purple' })
elif button == '4':
hass.services.call('light', 'turn_on', { "entity_id" : 'light.living_room_lightstrip', 'color_name': 'yellow' })
I though it should be (and I also tried):
button_obj = hass.states.get('sensor.hue_dimmer_1').state
And tried without the 'color_name'
option, and tried '1_click'
and '1_click_up'
instead of just 1, 2, 3, 4. It is executable, and I can run other python scripts from the same folder.
My working automation (with no python):
- alias: Dimmer 1 Button 1 Clicked
- platform: state
entity_id: sensor.hue_dimmer_1
to: '1_click_up' # sometimes it doesn't register very fast clicks. But it does register "click_up".
- service: light.turn_on
entity_id: light.living_room_lightstrip
etc…
@Aephir It appears my Hackster article is out of date, possible states (as your working automation show) are made up from:
responsecodes = {
'0' : "_click",
'1' : "_hold",
'2' : "_click_up",
'3' : "_hold_up"
You should just be able to parse the first character from the state using button = button_obj.state[0]
Is there any progress on turning this into an official component?
well there was, but it has been stopped, since the developer seems to have stopped developing it…
https://github.com/home-assistant/home-assistant/pull/15121#event-1780324242
too bad indeed, we were all looking forward to this anxiously.
Maybe @robmarkcole sees possibilities ? Are you still looking i to the asyncio side of things ?
#fingerscrossed.
we could all come in there and offer assistance how to get this going again?
thx,
Marius
Hmm, still not sure I get it. Fair warning, I’m extremely new to python…
I did try using 1_click
in the python script:
if button == '1_click':
hass.services.call('light', 'turn_on', { "entity_id" : 'light.living_room_lightstrip' })
etc.
if that’s what you mean?
