Husqvarna Automower monitoring
@Christian_Hollbjar Yes, I’ve seen the new API, and I started to look at what would be involved to move over to it – but – the new API doesn’t include GPS!! That, along with the current status, is my main reason for wanting this component.
@henninne You will need to use vacuum.start_pause which will toggle between running and paused.
@alexw This only works with the AutoConnect system, but it looks like Robonect supports MQTT and some guys have been working on that here: Robonect module in Husqavarna Automower via mqtt vacuum
