I can't connect via http locally, yet https works
What you’re describing is normal. Once you have SSL set up in Home Assistant you can only access (even locally) over HTTPS. The mobile apps can’t handle the cert warning, so you’d have to always use the external URL. Alternatively, you could use a reverse proxy (such as NGINX) to handle SSL and keep Home Assistant local access over HTTP.
