I have 2 warnings in logswondering if anyone can help
Your first error can be solved by providing a default after first and you can build safety in it by filtering out media players without last_called
{{ states.media_player | selectattr('attributes.last_called', 'defined') | selectattr('attributes.last_called','eq',true) | map(attribute='entity_id') | first | default(none) }}
I believe someone else answered the second error.
using this example breaks the whole thing and the last call function doesnt work anymore
You’ll have to post everything. I have Alexa media player and the template works as expected.
Thank you Petro! I had the original version:
    - name: "Last Alexa":
      unique_id: last_alexa
      state: "{{ states.media_player | selectattr('attributes.last_called','eq',true) | map(attribute='entity_id') | first }}"
which I have been using successfully for a while which correctly worked as a templated sensor but failed to render in the template editor for some weird reason!
I’ve taken your code one step further now and applied it to the name:
  - name: "{{ states.media_player | selectattr('attributes.last_called', 'defined') | selectattr('attributes.last_called','eq',true) | map(attribute='name') | first | default(none) }}"
    state: "{{ states.media_player | selectattr('attributes.last_called', 'defined') | selectattr('attributes.last_called','eq',true) | map(attribute='entity_id') | first | default(none) }}"
  - type: entities
    entities:
      - entity: sensor.last_alexa
        type: custom:multiple-entity-row
        show_state: false
        secondary_info: sensor.last_alexa
