I have a problem with state-controlled automations, can you help me?
I think it’s called Sisyphus, and it could as well be my second name :rofl:
if I change status manually it changes it, but it does not go but instead I do it automatically it does not even change the on / off status of the automation
What do you mean with “if I change manually it changes it”? What do you change manually and what changes?
The state of the automation in Developer Tools -> States must be “on” all the time. If it is “off” it means the automation is disabled and will not be executed, if it is “on” it is enabled. The state doesn’t change when the automation runs, it stays “on”.
Can you please provide the code for one of the working telegram notification automations?
thanks, I missed this step
solved thanks
What did solve your problem? Please mark the post that helped you solve the problem as the solution so that others are able to quickly see the solution in the future.
You should not change the name of the thread to mark it solved, you should mark the actual post (from burning or Taras that tipped you over the edge) as the solution.
Sneaky me removed the [solved] from the title :stuck_out_tongue_winking_eye:
So ‘Sneaky Pete’ ‘Sisiphus’ Burningstone ?
