How frequent are updates supposed to occur? The HA update is much smaller because of the frequent overwrites. I pulled it and then another a couple minutes later, but it seems that I was a little premature on the 2nd HA log.
||Line 144: 08-07 09:13:13.916 30611 30611 D LocBroadcastReceiver: Received geofence update.|
||Line 146: 08-07 09:13:14.129 30611 30611 D LocBroadcastReceiver: Event sent to Home Assistant|
||Line 147: 08-07 09:13:14.131 30611 30611 D LocBroadcastReceiver: Last Location: |
||Line 148: 08-07 09:13:14.131 30611 30611 D LocBroadcastReceiver: Coords:(xx.8903019, -xxx.3004275)|
||Line 149: 08-07 09:13:14.131 30611 30611 D LocBroadcastReceiver: Accuracy: 9.669|
||Line 150: 08-07 09:13:14.131 30611 30611 D LocBroadcastReceiver: Bearing: 217.0|
||Line 151: 08-07 09:13:14.131 30611 30611 D LocBroadcastReceiver: Begin evaluating if location update should be skipped|
||Line 152: 08-07 09:13:14.131 30611 30611 D LocBroadcastReceiver: Received location that is 1131 milliseconds old, 1659888793000 compared to 1659888794131 with source fused|
||Line 154: 08-07 09:13:14.359 30611 30676 D LocBroadcastReceiver: Location update sent successfully|
This is from logcat:
[08-07 09:13:13.916 30611:30611 D/LocBroadcastReceiver] Received geofence update.
[08-07 09:13:14.129 30611:30611 D/LocBroadcastReceiver] Event sent to Home Assistant
[08-07 09:13:14.131 30611:30611 D/LocBroadcastReceiver] Last Location:
Accuracy: 9.669
Bearing: 217.0
[08-07 09:13:14.131 30611:30611 D/LocBroadcastReceiver] Begin evaluating if location update should be skipped
[08-07 09:13:14.131 30611:30611 D/LocBroadcastReceiver] Received location that is 1131 milliseconds old, 1659888793000 compared to 1659888794131 with source fused
[08-07 09:13:14.359 30611:30676 D/LocBroadcastReceiver] Location update sent successfully
[08-07 09:19:10.847 30611:30611 D/LocBroadcastReceiver] Received geofence update.
[08-07 09:19:11.450 30611:30611 D/LocBroadcastReceiver] Event sent to Home Assistant
[08-07 09:19:11.451 30611:30611 D/LocBroadcastReceiver] Last Location:
Coords:(xx.891012, -xxx.2943736)
Accuracy: 3.9
Bearing: 130.90874
[08-07 09:19:11.451 30611:30611 D/LocBroadcastReceiver] Begin evaluating if location update should be skipped
[08-07 09:19:11.451 30611:30611 D/LocBroadcastReceiver] Received location that is 816 milliseconds old, 1659889150635 compared to 1659889151451 with source fused
[08-07 09:19:11.783 30611:31470 D/LocBroadcastReceiver] Location update sent successfully
Also, as I write this, my wife went to the store. The geocoded location is perfectly accurate, but the device_tracker, as usual, has only moved ~100’ from our house. I won’t be able to pull anything until she gets home.
