I need help with my configuration.yaml switches
Im trying to make my code for some switches to be inverted from the others
# Loads default set of integrations. Do not remove.
default_config:
# Text to speech
tts:
  - platform: google_translate
automation: !include automations.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
# Full configuration.yaml entry
# Example configuration.yaml entry
switch:
  - platform: rpi_gpio
    switches:
      - port: 16
        unique_id: "Controles"
      - port: 24
        unique_id: "Abanicos"
        invert_logic: true
      - port: 25
        name: "Area de Trabajo"
        unique_id: "Area_de_trabajo"
      - port: 12
        unique_id: "Labora"
      - port: 26
        unique_id: "Puerta"
      - port: 23
        unique_id: "Closed"
this is my right now codes, the first two (Controles and Abanicos) Are working great but the others are inverted, i tried putting a inverted at the end two but it keeps doing the same, when i turn it on it turns off
Can some one help pls? i’m really needing it right now
I’m confused- but what’s new about that?
To the best of my knowledge, rpi_gpio is depreciated. But I don’t use the Raspberry Pi, so what do I know?
This may help.
Since my switches are all ESPHome devices (or Z-Wave), I don’t use the switch: component in my configuration.yaml file.
Its posible using the rpi_gpio by hacs but right now im having a problem with my switches because the ones that are supossed to be inverted are working great but then all the other ones are inverted too, i tried to make a separation by doing this
default_config:
# Text to speech
tts:
switch: !include switch.yaml
switches: !include switches.yaml
by making two separate files and in one putting the one i want to be inverted and the other ones to be normal
