I need help with script parameter
Im trying to use one script (toggle) many climate devices.
For example tap action:
tap_action:
  action: call-service
  service: script.toggle_heater
    tentity: climate.f1a1
and script:
toggle_heater:
  alias: toggle_heater
  - if:
    - condition: and
      conditions:
      - condition: template
        value_template: >-
            {% set device = '{{ tentity }}' %}
            {{ is_state('climate.f1a1', 'heat') }}
    then:
    - service: climate.turn_off
         entity_id: '{{ tentity }}'
But without success (else condition missing but they are similar) :frowning:
I need help what I’m doing wrong ?
Is it possible to send parameter in this way?
Thank you in advance :slight_smile:
toggle_heater:
      value_template: "{{ is_state(tentity, 'heat') }}"
Cannot determine status in if condition.
Current status from developer tools for this device is “heat”
But result in script is false:
Result:
result: false
condition: template
value_template: '{{ is_state(tentity, ''heat'') }}'
Still not working.
Thank you for suggestion :slight_smile:
If the script didn’t receive a value of climate.f1a1 in the tentity variable then there may be an issue with how tap_action is configured.
Try this version:
tap_action:
  service_data:
    tentity: 'climate.f1a1'
toggle_heater:
    - variables:
        t: "{{ tentity | default('climate.f1a1', true) }}"
      value_template: "{{ is_state(t, 'heat') }}"
        entity_id: '{{ t }}'
When I try to toggle f1a2 device
tap_action:
    tentity: climate.f1a2
double_tap_action:
  action: more-info
Device f1a1 going to turn off.
I designed the script to use climate.f1a1 by default if it doesn’t receive a value for tentity.
The results of your test prove that the script is not receiving a value for tentity.
I suggest you try the version I had suggested which uses service_data instead of data.
tap_action:
  service_data:
double_tap_action:
  action: more-info
Yeeee now working as expected.
Thank you :sunglasses:
Now second question how to make else ?
You will need to provide more details about what you want to do because “make else” isn’t sufficiently clear.
toggle_heater:
    variables:
    if:
    else:
    - service: climate.set_temperature
        temperature: input_number.default_climate_themperature
    	hvac_mode: heat
Something similar like this but this not working :frowning:
toggle_heater:
    - variables:
    - if:
      then:
      else:
            temperature: "{{ states('input_number.default_climate_themperature') }}"
            hvac_mode: heat
EDIT
Correction. Overlooked to include hyphens.
For something reason script is not loaded:
Script is unavailable
Actions: extra keys not allowed @ data[0][‘if’]
toggle_heater:
    - variables:
    - if:
      then:
      else:
              hvac_mode: heat
This work as expected :sunglasses:
Thank you very much " 123Taras"
That’s due to my mistake. I have corrected the example posted above.
You’re welcome!
Please consider marking my post above with the Solution tag. It will automatically place a check-mark next to the topic’s title which signals to other users that this topic has been resolved. This helps users find answers to similar questions.
For more information about the Solution tag, refer to guideline 21 in the FAQ.
