So about an hour ago I got hacked too - I know I was hacked as the lights and switches started going on and off by themselves and out of google home came a very loud msg stating that “YOUR PLACE IS A MESS” over and over. I had 443 and 1883 open at the time (I’m running HA 0.72.1 WIN 10 and HASSIO on a RPI 3), it was the Win 10 HA that was compromised tho as that’s where the tts msg was stored. These are the logs that I have…
2018-07-09 15:11:16 ERROR (MainThread) [frontend.js.latest.201807080] http://my_ext_ip_addr:443/api/panel_custom/alarm:248:47 Uncaught TypeError: Cannot read property 'LocalizeMixin' of undefined
2018-07-09 15:11:21 ERROR (MainThread) [frontend.js.latest.201807080] http://my_ext_ip_addr:443/local/custom_ui/floorplan/ha-floorplan.html:375:25 Uncaught TypeError: Polymer.dom is not a function
2018-07-09 15:11:24 ERROR (MainThread) [frontend.js.latest.201807080] http://my_ext_ip_addr:443/local/custom_ui/floorplan/ha-floorplan.html:375:25 Uncaught TypeError: Polymer.dom is not a function
2018-07-09 15:11:29 ERROR (MainThread) [frontend.js.latest.201807080] http://my_ext_ip_addr:443/local/custom_ui/floorplan/ha-floorplan.html:375:25 Uncaught TypeError: Polymer.dom is not a function
2018-07-09 15:11:30 ERROR (MainThread) [frontend.js.latest.201807080] http://my_ext_ip_addr:443/local/custom_ui/floorplan/ha-floorplan.html:375:25 Uncaught TypeError: Polymer.dom is not a function
2018-07-09 15:11:41 ERROR (MainThread) [frontend.js.latest.201807080] http://my_ext_ip_addr:443/local/custom_ui/floorplan/ha-floorplan.html:375:25 Uncaught TypeError: Polymer.dom is not a function
2018-07-09 15:11:42 ERROR (MainThread) [frontend.js.latest.201807080] http://my_ext_ip_addr:443/local/custom_ui/floorplan/ha-floorplan.html:375:25 Uncaught TypeError: Polymer.dom is not a function
2018-07-09 15:11:49 ERROR (MainThread) [frontend.js.latest.201807080] http://my_ext_ip_addr:443/local/custom_ui/floorplan/ha-floorplan.html:375:25 Uncaught TypeError: Polymer.dom is not a function
2018-07-09 15:11:52 ERROR (MainThread) [frontend.js.latest.201807080] http://my_ext_ip_addr:443/local/custom_ui/floorplan/ha-floorplan.html:375:25 Uncaught TypeError: Polymer.dom is not a function
2018-07-09 15:11:53 ERROR (MainThread) [frontend.js.latest.201807080] http://my_ext_ip_addr:443/local/custom_ui/floorplan/ha-floorplan.html:375:25 Uncaught TypeError: Polymer.dom is not a function
2018-07-09 15:11:55 ERROR (MainThread) [frontend.js.latest.201807080] http://my_ext_ip_addr:443/local/custom_ui/floorplan/ha-floorplan.html:375:25 Uncaught TypeError: Polymer.dom is not a function
2018-07-09 15:11:57 ERROR (MainThread) [frontend.js.latest.201807080] http://my_ext_ip_addr:443/api/panel_custom/alarm:248:47 Uncaught TypeError: Cannot read property 'LocalizeMixin' of undefined
'python3' is not recognized as an internal or external command,
operable program or batch file.
2018-07-09 15:15:26 ERROR (SyncWorker_15) [homeassistant.components.switch.command_line] Command failed: python3 "/config/python_scripts/SayOff.py"
2018-07-09 15:15:35 ERROR (SyncWorker_15) [homeassistant.components.switch.command_line] Command failed: python3 "/config/python_scripts/SayOn.py"
2018-07-09 15:15:57 ERROR (MainThread) [homeassistant.components.camera.generic] Error parsing template <homeassistant.helpers.template.Template object at 0x07E0A390>: UndefinedError: 'None' has no attribute 'attributes'
2018-07-09 15:16:12 ERROR (MainThread) [homeassistant.components.camera.generic] Error parsing template <homeassistant.helpers.template.Template object at 0x07E0A390>: UndefinedError: 'None' has no attribute 'attributes'
2018-07-09 15:16:13 ERROR (MainThread) [aiohttp.server] Unhandled exception
File "C:\Users\Keith\AppData\Local\Programs\Python\Python36-32\lib\site-packages\aiohttp\web_protocol.py", line 398, in start
await resp.prepare(request)
File "C:\Users\Keith\AppData\Local\Programs\Python\Python36-32\lib\site-packages\aiohttp\web_response.py", line 300, in prepare
return await self._start(request)
File "C:\Users\Keith\AppData\Local\Programs\Python\Python36-32\lib\site-packages\aiohttp\web_response.py", line 605, in _start
return await super()._start(request)
File "C:\Users\Keith\AppData\Local\Programs\Python\Python36-32\lib\site-packages\aiohttp\web_response.py", line 367, in _start
await writer.write_headers(status_line, headers)
File "C:\Users\Keith\AppData\Local\Programs\Python\Python36-32\lib\site-packages\aiohttp\http_writer.py", line 100, in write_headers
self._write(buf)
File "C:\Users\Keith\AppData\Local\Programs\Python\Python36-32\lib\site-packages\aiohttp\http_writer.py", line 57, in _write
raise ConnectionResetError('Cannot write to closing transport')
ConnectionResetError: Cannot write to closing transport
2018-07-09 15:16:23 ERROR (MainThread) [homeassistant.components.camera.generic] Error parsing template <homeassistant.helpers.template.Template object at 0x07E0A390>: UndefinedError: 'None' has no attribute 'attributes'
2018-07-09 15:16:32 ERROR (MainThread) [homeassistant.components.camera.generic] Error parsing template <homeassistant.helpers.template.Template object at 0x07E0A390>: UndefinedError: 'None' has no attribute 'attributes'
2018-07-09 15:16:42 ERROR (MainThread) [homeassistant.components.camera.generic] Error parsing template <homeassistant.helpers.template.Template object at 0x07E0A390>: UndefinedError: 'None' has no attribute 'attributes'
2018-07-09 15:16:52 ERROR (MainThread) [homeassistant.components.camera.generic] Error parsing template <homeassistant.helpers.template.Template object at 0x07E0A390>: UndefinedError: 'None' has no attribute 'attributes'
2018-07-09 15:18:13 ERROR (MainThread) [aiohttp.server] Unhandled exception
self._write(buf)
2018-07-09 15:18:43 ERROR (MainThread) [homeassistant.components.camera.generic] Error parsing template <homeassistant.helpers.template.Template object at 0x07E0A390>: UndefinedError: 'None' has no attribute 'attributes'
2018-07-09 15:18:53 ERROR (MainThread) [homeassistant.components.camera.generic] Error parsing template <homeassistant.helpers.template.Template object at 0x07E0A390>: UndefinedError: 'None' has no attribute 'attributes'
2018-07-09 15:20:16 ERROR (MainThread) [homeassistant.components.camera.generic] Error parsing template <homeassistant.helpers.template.Template object at 0x07E0A390>: UndefinedError: 'None' has no attribute 'attributes'
2018-07-09 15:20:38 ERROR (MainThread) [homeassistant.components.camera.generic] Error parsing template <homeassistant.helpers.template.Template object at 0x07E0A390>: UndefinedError: 'None' has no attribute 'attributes'
2018-07-09 15:20:38 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback _ProactorReadPipeTransport._loop_reading(<_OverlappedF...op_reading()]>)
File "C:\Users\Keith\AppData\Local\Programs\Python\Python36-32\lib\asyncio\events.py", line 145, in _run
self._callback(*self._args)
File "C:\Users\Keith\AppData\Local\Programs\Python\Python36-32\lib\asyncio\proactor_events.py", line 190, in _loop_reading
data = fut.result() # deliver data later in "finally" clause
asyncio.base_futures.InvalidStateError: Result is not set.
2018-07-09 15:20:48 ERROR (MainThread) [homeassistant.components.camera.generic] Error parsing template <homeassistant.helpers.template.Template object at 0x07E0A390>: UndefinedError: 'None' has no attribute 'attributes'
2018-07-09 15:20:58 ERROR (MainThread) [homeassistant.components.camera.generic] Error parsing template <homeassistant.helpers.template.Template object at 0x07E0A390>: UndefinedError: 'None' has no attribute 'attributes'
2018-07-09 15:21:08 ERROR (MainThread) [homeassistant.components.camera.generic] Error parsing template <homeassistant.helpers.template.Template object at 0x07E0A390>: UndefinedError: 'None' has no attribute 'attributes'
2018-07-09 15:21:09 ERROR (MainThread) [homeassistant.components.camera.generic] Error parsing template <homeassistant.helpers.template.Template object at 0x07E0A390>: UndefinedError: 'None' has no attribute 'attributes'
2018-07-09 15:21:09 ERROR (MainThread) [aiohttp.server] Unhandled exception
self._write(buf)
2018-07-09 15:21:18 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback _ProactorReadPipeTransport._loop_reading(<_OverlappedF...op_reading()]>)
2018-07-09 15:21:18 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback _ProactorReadPipeTransport._loop_reading(<_OverlappedF...88d\xd5r\xac'>)
File "C:\Users\Keith\AppData\Local\Programs\Python\Python36-32\lib\asyncio\proactor_events.py", line 188, in _loop_reading
self._closing)
AssertionError
2018-07-09 15:21:18 ERROR (MainThread) [homeassistant.components.camera.generic] Error parsing template <homeassistant.helpers.template.Template object at 0x07E0A390>: UndefinedError: 'None' has no attribute 'attributes'
2018-07-09 15:21:22 ERROR (MainThread) [homeassistant.components.camera.generic] Error parsing template <homeassistant.helpers.template.Template object at 0x07E0A390>: UndefinedError: 'None' has no attribute 'attributes'
2018-07-09 15:21:24 ERROR (Thread-14) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2018-07-09 15:21:28 ERROR (MainThread) [aiohttp.server] Unhandled exception
self._write(buf)
2018-07-09 15:21:37 ERROR (SyncWorker_14) [homeassistant.components.sensor.rest] Error fetching data: <PreparedRequest [GET]> from http://192.168.178.30:8080/sensors.json?sense=motion_active failed with HTTPConnectionPool(host='192.168.178.30', port=8080): Max retries exceeded with url: /sensors.json?sense=motion_active (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x0CDCFC70>, 'Connection to 192.168.178.30 timed out. (connect timeout=10)'))
2018-07-09 15:21:48 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback _ProactorReadPipeTransport._loop_reading(<_OverlappedF...\x1d\xd8\xc1'>)
self._closing)
AssertionError
2018-07-09 15:21:55 ERROR (MainThread) [pydroid_ipcam] Failed to communicate with IP Webcam: Cannot connect to host 192.168.178.30:8080 ssl:None [The semaphore timeout period has expired]
2018-07-09 15:22:08 ERROR (SyncWorker_6) [homeassistant.components.sensor.rest] Error fetching data: <PreparedRequest [GET]> from http://192.168.178.30:8080/sensors.json?sense=motion_active failed with HTTPConnectionPool(host='192.168.178.30', port=8080): Max retries exceeded with url: /sensors.json?sense=motion_active (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x07B647D0>, 'Connection to 192.168.178.30 timed out. (connect timeout=10)'))
2018-07-09 15:22:10 ERROR (MainThread) [homeassistant.components.camera.generic] Error parsing template <homeassistant.helpers.template.Template object at 0x07E0A390>: UndefinedError: 'None' has no attribute 'attributes'
2018-07-09 15:22:20 ERROR (MainThread) [homeassistant.components.camera.mjpeg] Timeout getting camera image
2018-07-09 15:22:27 ERROR (MainThread) [pydroid_ipcam] Failed to communicate with IP Webcam: Cannot connect to host 192.168.178.30:8080 ssl:None [The semaphore timeout period has expired]
2018-07-09 15:22:39 ERROR (SyncWorker_8) [homeassistant.components.sensor.rest] Error fetching data: <PreparedRequest [GET]> from http://192.168.178.30:8080/sensors.json?sense=motion_active failed with HTTPConnectionPool(host='192.168.178.30', port=8080): Max retries exceeded with url: /sensors.json?sense=motion_active (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x0AFF91B0>, 'Connection to 192.168.178.30 timed out. (connect timeout=10)'))
2018-07-09 15:22:59 ERROR (MainThread) [pydroid_ipcam] Failed to communicate with IP Webcam: Cannot connect to host 192.168.178.30:8080 ssl:None [The semaphore timeout period has expired]
2018-07-09 15:23:02 ERROR (MainThread) [homeassistant.components.camera.generic] Error parsing template <homeassistant.helpers.template.Template object at 0x07E0A390>: UndefinedError: 'None' has no attribute 'attributes'
2018-07-09 15:23:10 ERROR (SyncWorker_17) [homeassistant.components.sensor.rest] Error fetching data: <PreparedRequest [GET]> from http://192.168.178.30:8080/sensors.json?sense=motion_active failed with HTTPConnectionPool(host='192.168.178.30', port=8080): Max retries exceeded with url: /sensors.json?sense=motion_active (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x0A0309D0>, 'Connection to 192.168.178.30 timed out. (connect timeout=10)'))
Not sure if the above will help or not, both of my HA’s are password protected.
