@henrikrox
The iCloud3 documentation is here
Iām having an issue getting the 2FA to work for my iCloud account. I have the persistent notification where you can put in a 6-digit code to authenticate, but I canāt get the ātrusted deviceā one to show up. Iāve tried clearing the iCloud cookie file and Iāve restarted and reinstalled many times as well. I also tried the āreset iCloud interfaceā option in the widget and it hasnāt changed anything. Any help would be appreciated!
@garretbeachyā
The iCloud session data is stored in 2 places - the cookie file in the .storage/icloud
directory and the trusted device authentication info in the .storage/icloud/session
directory. The data itself is in a file based on your iCloud account email address. When you delete just the cookie file, the session is still valid. Resetting the iCloud Interface on the Event Log > Action button renames both of these and then reauthenticates your account.
Try renaming the .storage/icloud
directory to something else and restart Home Assistant. The cookies and session files will be recreated and that should cause the notification on your phone and the code entry window selection option to be available in the HA notification area.
Question - The code entry window is selected from the HA notification area. I assume You have been going there to open the window. See the docs here for more info
Just recently Iāve started getting Apple iOS notifications that a device is trying to access my account. I go ahead and approve it, and it gives me a 6 digit code. In HA I get a persistent notification telling me to use the configurator to enter the code sent by Apple. I enter it, but it doesnāt work. If I try the configurator again, it tells me the code is invalid.
I already tried renaming the iCloud directory, to no avail.
@FutureTense
Try resetting the iCloud Interface on Event Log > Actions. See here for more info.
If it looks like the code is not accepted, check your iCloud account. Sign out of it and then sign back in. Then do the reset above again.
Unfortunately Iāve never been unable to install the iCloud interface. Iām trying to go down that rabbit hole again.
If you are not using the
www/custom_cards
directory, use your directory name (e.g.,www/community
) instead ofwww/custom_cards
in the following instructions. Then, use the iCloud3 event_log_card_directory: www/yourcustomcarddirectoryname configuration parameter to specify your directory name.
Please provide an example on how to do this in configuration.yaml.
@FutureTense
See iCloud3 docs for instructions on installing the Event Log.
- Setting up the Lovelace Resource is here. Change the
/local/custom_cards/icloud3-event-log-card.js
to/local/YOURDIRECTORY/icloud3-event-log-card.js
- You may also have to set the
config_ic3_file_name
iCloud3 configuration parameter to that directory. See the iCloud3 doce here.
The Event Log install instructions have a manual set up for the Lovelace resource here that might be helpful.
And just exactly how do you specify config_ic3_file_name
in configuration.yaml? The only thing that I have in configuration.yaml with respect to icloud3 is:
device_tracker:
- platform: icloud3
username: [email protected]
password: xxx
devices:
- device_name: iphone_me
email: [email protected]
- device_name: iphone_her
And I see nothing in the documentation on how to actually define config_ic3_file_name inside of configuration.yaml. Putting it at the root level gives an error. Can you please provide an example?
I gave you the wrong parameter name for the Event Log file location. It is actually event_log_card_directory
. Sorry for that. You can find info about this parameter here.
device_tracker:
- platform: icloud3
password: xxx
devices:
event_log_card_directory: /www/community/
I have mine in the /www/custom_cards
directory (the default). If it is another location, use that location instead of the /www/community
Note: The parameters are indented 4-spaces, just like the username, pasword and devices parameter.
Arghh, itās config_ic3_file_name Iām having a problem with right now.
Your documentation appears to be incorrect.
The following does not work, as your documentation suggests to follow:
device_tracker:
- platform: icloud3
config_ic3_file_name: 'config/my_ic3.yaml'
But removing the leading config
works.
device_tracker:
- platform: icloud3
config_ic3_file_name: 'my_ic3.yaml'
Youāre referring me to āthe documentationā, which Iām following verbatim in this instance and itās not working. Thatās why I asked for an example.
EDIT: Cleared known_deivces.yaml reboot HA and problem solved
Hi All,
I get this error:
iCloud3 Setup Error > iphone_van_peter > The iOS App device_tracker entity was not found in the Entity Registry for this device.
iCloud3 Setup Error > cenkays_iphone > The iOS App device_tracker entity was not found in the Entity Registry for this device.
devices:
- device_name: "iphone_van_peter"
picture: "local/images/person/peter-home.png"
- device_name: "cenkays_iphone"
picture: "local/images/person/kay-home.png"
noiosapp: true
The sensors are working normal. cenkays_iphone not using the iOS app as you can see in devices.
I use the iOS app and that is a different nameā¦ I cant change the name because iCloud3 have the entitiy name already, and i cant delete it because of:
This entity (ādevice_tracker.peter_iphoneā) does not have a unique ID, therefore its settings cannot be managed from the UI. See the documentation for more detail.
- I looked through the docs to see where the example is that has
config/config_ic3.yaml
as an example without the slash before the config and didnāt see it. I did see thedefault: config/config_ic3.yaml
. Is that what you mean? - The parsing sequence for the config_ic3.yaml file is shown here. I just have a
config_ic3.yaml
file in the /config directory. - There are some parameters that are used to set up iCloud3 and must be in the configuragion.yaml file. There are the username, password, config_ic3 file_name, create_sensors & exclude_sensors and described in the same section. All others can be in the config_ic3.yaml (your
my_ic3.yaml
# in configuration.yaml
device_tracker:
- platform: icloud3
password: xxx
config_ic3_file_name: my_ic3.yaml
# in my_ic3.yaml file
devices:
@poudenes
The iCloud phone name (General/about/Name) and iCloud3 devicename (config devices parameter) must be the same. (iPhone Van Peter = iphone_van_peter). Normally, adding the mobile_device when iCloud3 is running will add a suffix (_2) onto itās device_tracker name (iphone_van_peter_2) and iCloud3 will find it since it starts with iphone_van_peter. If you have set the phone name (iOS App Configuration Device Name) to something else, iC3 will not find the device in the entity registry and not be able to monitor it.
Use the iosapp_entity parameter to specify another name.
devices:
iosapp_entity: "iosapp_van_peter" ---> What you have in the app configuration, device name
Thanks for the reply!
Everything is working, only I donāt get the info of the other iCloud account. All the time notset. Even wen I try to get location information
@poudenes
That does indicate the phone is not being monitored. When iCloud3 starts, all the device_tracker entities are listed in Stage 3 of the Event Log. Put the non-monitored one in the iosapp_entity
parameter for the device not being monitored.
@poudenes
Now I understand, That is normal since the iOS App is not monitored. I have changed the text to Not Used in the next version when the iOS App is not monitored to avoid confusion.
So it will be this then: when I read document ānoiosappā is depreciated parameters
and iosapp_installed: False will be the replacement
devices:
now its working I see the updates and distance changingā¦ He will be happy, because he is biking all day to change location so I can test it hahaha
Stupid question perhaps.
But my person didnāt have a device tracker. am I supposed to use iphone_app that is generated when installing the HA app, or the device_tracker.henrik_iphone (generated by icloud3). Am I just a bit confused if I use iOS app (Henrik_iphone_app) if its using the gps from iCloud or from the iOS app.
also after doing a restart, my battery is missing a number (see the drop, its 76%, but it shows as 7%.
My iOS settings name app is Henrik iPhone and my HA iOS app name is Henrik-iPhone
@henrikrox
You want to use device tracker.henrik_iphone for your location tracking. The one with the_app is the device tracker associated with the ios app that is monitored by iCloud3. iCloud3 uses both the ios app location and the iCloud location.
There are times when the battery info is not available and is not reported.
