I used the UI edit function to add this card. Did you restart HA Core before attempting to add the card?
NVM, it seems to have fixed itself after a bounce of HA.
@Garyk Yes. I added the js resource and restarted. Then I tried to add the card through the Dashboard add card functionality, and it gives that error.
Intervall says 2h
Did you install the add-on through HACS or manually? Iāve kept my installation manual, so may be different than yours.
@GaryK Yes, installed through HACS. I have other custom components installed through HACS working correctly. I tried manually and didnāt get quite as far. Iām probably missing a step. I had to create www under /config, The complete path is /config/www/custom_cards/icloud3-event-log-card.js, which I had to copy from the icloud3 directory and figured out based on the manual instructions. Reading the manual instructions, it seems like /config/www is equivalent to /local, but thereās no symlink between the two, so /local must be in the code of HA somewhere.
You appear to have the code in the correct locations, and yes, /config/www is equivalent to /local. Apart for the custom card, does IC3 generate a device_tracker entity? Is the component running?
@GaryK I think the integration is running, but without knowing how to find the log lines in the db, Iām not sure.
There is also a ācardā that was generated called āMobile Appā in Configuration ā Devices & Services in the Integration Tab with my three iphones. I think those are populated because I have a manually entered device_tracker of my Apple ID in the configuration.yaml, and the three phones are manually entered in the config_ic3.yaml. I had previously installed the official icloud integration, so some of this may be āechoesā of that installation (which I had removed prior to installing icloud3.
The Mobile App ācardā provides information on the various entities created by the iOS/Android mobile apps and is unrelated to IC3. hen you do get IC3 properly configured, you may need to rename the device_tracker entity so that it doesnāt conflict with the IC3.
event_log_card_directory: 'www/custom_cards'
specified in your config_ic3.yaml
file?
IC3 generates itās own device_tracker entity. I have two device_tracker entities. One from the iOS app and one from IC3.
installed it via HACS
also when installing manuallyā¦
I get these when my GPS signal is weak or blocked somehow. I sometimes request a location update to clear this condition.
@GaryK Yes, I have that entry in the config_ic3.yaml. Iāve confirmed the configuration about 10 times at least. lol. Hereās the config from the card on the dashboard:
type: custom:icloud3-event-log-card
entity: sensor.icloud3_event_log
icon: mdi:information-outline
title: iCloud3 Event Log
And this is the error that shows up in the card I added to the dashboard:
`Custom element doesnāt exist: icloud3-event-log-card.
type: custom:icloud3-event-log-card entity: sensor.icloud3_event_log icon: mdi:information-outline title: iCloud3 Event Log`
Do you have sensor.icloud3_event_log
under Developer Tools > States?
Yes. With some errors about not being able to set up icloud3, but I just checked the username and password entries, and theyāre correct.
I just sent you a message with the gnarly details. It looks like itās just failing on my wifeās phone. My phone seems to be working.
Iām stumped. Perhaps change your secrets in device_tracker to their actual values. The device_tracker values are your Apple iCloud credentials, correct? Verify device names and emails are accurate and known to Apple iCloud.
I really appreciate the help. I think icloud3 is working (short of the phone details for my wife). I canāt figure out this card issue for the life of me, however.
Youāve cleared the cache on your browser havenāt you. Maybe gcobb321 will come on and help us both figure out your issue.
