If the ping is performed from the ESP then it would work.
Is it possible to ping an IP address from inside an ESPHome node? - ESPHome - Home Assistant Community (home-assistant.io)
or
Which one was it?
I would think it makes a difference.
Things are getting mixed here i have counted three options so far;
- develop your esphome solution to control the socket. Esphome would ping your router and decide to toggle your socket. Totally independent to HA, no automation is needed here.
- go with zigbee or zwave, set up an automation in HA to ping router and send commands to zigbee/zwave socket, no internet is needed
- if your local network is running without router (we know yours is not capable), you can still ping router from HA and set an automation to toggle any local network operating socket (localtuya or tasmota)
Ok I can see how that would be confusing.
So what i meant is when the issue happened, my Google wifi mesh lost wifi for some unknown reason. The google router still had internet coming in. The google router was hard wired to my HA, hence I still had cloud access to my HA, but from my HA I had no access to anything that was using Wifi. (Not many devices, as most are Zwave/Zigb)
So as long as I have cloud access to HA AND my google wifi points are now connected to smart outlets using either zwave/zigbee, I could toggle power to them remotely and hopefully get the wifi back up.
But I was also asking for a solution where in lets assume I did lose complete cloud acess to my HA device because the google wifi router flaked out. I want to be able to cycle power to the google wifi points.
Make sense now hopefully? And I think this thread has given me some great solutions.,
Perhaps this is obvious, but you can power it off, but not on.
As soon as you power off the outlet to the router your access in is lost.
So remember to add an automation to power it back on when it is off with a smal delay
Yes! Cant forget that lol. Im making a automation tied to a input_boolean that would cut power, wait 10 sec and then power up again. Then if the input boolean is not turned off within 10 min (meaning I havent regained access), repeat the process
Alright heres my solution as of now. Every 10 min, HA pings my two wifi points and google. Depending on where the failure is, it toggles power to the outlet powering that wifi point / router & modem. Rinse, repeat.
I would like to emphasize it, STAY AWAY FROM TUYA
Here a lot about Tuya; probably because of the recent Home Assistant releases. I may be completely wrong, but is Tuya a software IoT solution and hardware vendors implement devices to support Tuya so that they do not need to get into the software business?
Why should we stay away from Tuya? What is your preferred solution?
A wifi switch loaded with ESPHome that is set up to toggle if it loses contact with Home Assistant.
Is there any tutorial anywhere on how to do this?
Not that I know of.
Using Tasmota:
Watchdog for Wi-Fi router~
A Tasmota socket can ping a remote host (router itself or something else connected to the router) and power cycle the socket to reboot the router. In this example, ping interval of 3 minutes is used. The simplest watchdog rule does not use variables:
Rule1
ON Time#Minute|3 DO Ping4 192.168.1.10 ENDON
ON Ping#192.168.1.10#Success==0 DO Backlog Power1 0; Delay 10; Power1 1; ENDON
Rule1 1
You are right about Tuya is software but it is also producing hardware for brands. So, anyone can order some smart home stuff from Tuya with their own logo and brand, and you have a new brand. They can even use rebranded mobile app, identical to tuya/smartlife. My warning was about tuya wifi, i am not against any ZigBee or zwave products.
I am a heavy tuya wifi user (blinds socket, thermostats, plugs) and all are over localtuya.
Would it be possible to do the same thing with a Shelly Script?
My router is connected to a Shelly and would like to have the ability to reboot it when I’m not at home.
Moreover, if someone accidentally turn the Shelly switch off I want it to turn it on again after a fixed time, in order to not be cut out from my house when I’m away.
When my router is off all network devices cannot communicate, so the automation has to be stored and executed on the Shelly itself.
In the latter case I think it would be also wise to implement a “safe rule” to avoid to turn the switch on again and again in case of some kind of malfunction.
I answer myself I don’t need a Shelly’s script to achieve that, there is a native timer function to auto turn on a switch.
@nappyjim
Could you share your Node-Red flow, I have similar setup to you and want to achieve the same thing.
How has it been since you implemented it, ever so often I have the same issue with my Google Router and Points, which requires a quick reboot.
[{"id":"c732e1825055b946","type":"tab","label":"Flow 3","disabled":false,"info":"","env":[]},{"id":"c33e68381f5612cd","type":"inject","z":"c732e1825055b946","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"600","crontab":"","once":false,"onceDelay":0.1,"topic":"","payloadType":"date","x":160,"y":180,"wires":[["1258d3f7b282fc21","d3dd34874bfbb717","f69c3b079629a664"]]},{"id":"1258d3f7b282fc21","type":"ping","z":"c732e1825055b946","protocol":"IPv4","mode":"triggered","name":"Ping laundry room","host":"192.168.86.43","timer":"20","inputs":1,"x":384,"y":126,"wires":[["bd14c65195ca3dd5"]]},{"id":"bd14c65195ca3dd5","type":"switch","z":"c732e1825055b946","name":"FAILURE?","property":"payload","propertyType":"msg","rules":[{"t":"false"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":574,"y":135,"wires":[["1894ab4131cf9e60","67587e0ae5bf59b2"],[]]},{"id":"adf49c05c913f3af","type":"api-call-service","z":"c732e1825055b946","name":"OFF: Outlet laundry wifi point","server":"ab3e2c53.e3491","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.outlet_laundry_room_wifi_point"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":834,"y":126,"wires":[["5457e178a98e1aa8"]]},{"id":"5457e178a98e1aa8","type":"trigger","z":"c732e1825055b946","name":"Wait 25s","op1":"","op2":"0","op1type":"nul","op2type":"str","duration":"25","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":1084,"y":126,"wires":[["bee697ab6c02ec9e"]]},{"id":"bee697ab6c02ec9e","type":"api-call-service","z":"c732e1825055b946","name":"ON: Outlet laundry room wifi point","server":"ab3e2c53.e3491","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.outlet_laundry_room_wifi_point"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1317,"y":126,"wires":[[]]},{"id":"d3dd34874bfbb717","type":"ping","z":"c732e1825055b946","protocol":"IPv4","mode":"triggered","name":"Ping: Guest room","host":"192.168.86.24","timer":"20","inputs":1,"x":374,"y":171,"wires":[["bd14c65195ca3dd5"]]},{"id":"1894ab4131cf9e60","type":"switch","z":"c732e1825055b946","name":"Which one?","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"192.168.86.22","vt":"str"},{"t":"eq","v":"192.168.86.24","vt":"str"},{"t":"eq","v":"www.google.com","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":574,"y":201,"wires":[["adf49c05c913f3af"],["de8cb2aaf342fd26"],["66b3a1b9d6c77852"]]},{"id":"f69c3b079629a664","type":"ping","z":"c732e1825055b946","protocol":"IPv4","mode":"triggered","name":"Ping: google","host":"www.google.com","timer":"20","inputs":1,"x":359,"y":216,"wires":[["bd14c65195ca3dd5"]]},{"id":"66b3a1b9d6c77852","type":"api-call-service","z":"c732e1825055b946","name":"OFF: Outlet office wifi point","server":"ab3e2c53.e3491","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.outlet_office_wifi_point"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":830,"y":216,"wires":[["c8460364b2bbbc9c"]]},{"id":"a151d1e9d8c3be16","type":"api-call-service","z":"c732e1825055b946","name":"ON: Outlet office wifi point","server":"ab3e2c53.e3491","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.outlet_office_wifi_point"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1287,"y":216,"wires":[[]]},{"id":"c8460364b2bbbc9c","type":"trigger","z":"c732e1825055b946","name":"Wait 25s","op1":"","op2":"0","op1type":"nul","op2type":"str","duration":"25","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":1084,"y":216,"wires":[["a151d1e9d8c3be16"]]},{"id":"de8cb2aaf342fd26","type":"api-call-service","z":"c732e1825055b946","name":"OFF: Outlet guest room wifi point","server":"ab3e2c53.e3491","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.outlet_guest_room_wifi_point"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":850,"y":171,"wires":[["cdcd4724920c13ac"]]},{"id":"32db9d299311bd80","type":"api-call-service","z":"c732e1825055b946","name":"ON: Outlet guest room wifi point","server":"ab3e2c53.e3491","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.outlet_guest_room_wifi_point"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1307,"y":171,"wires":[[]]},{"id":"cdcd4724920c13ac","type":"trigger","z":"c732e1825055b946","name":"Wait 25s","op1":"","op2":"0","op1type":"nul","op2type":"str","duration":"25","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":1084,"y":171,"wires":[["32db9d299311bd80"]]},{"id":"2891a682ab26faff","type":"comment","z":"c732e1825055b946","name":"Check for lost wifi and internet","info":"","x":195,"y":60,"wires":[]},{"id":"67587e0ae5bf59b2","type":"link out","z":"c732e1825055b946","name":"Wifi failure","mode":"link","links":["95021f15f4f356e9","158b1f2754ae9b9b"],"x":744,"y":51,"wires":[]},{"id":"ab3e2c53.e3491","type":"server","name":"AvilaSmartHome","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
