Ideas on how to detect boiler lockout?
Here is something else you can take away for potential diagnostics too:
alias: Heating Timer
description: Make sure heating doesn't run longer than 2 hours.
  - platform: event
    event_type: timer.finished
    event_data:
      entity_id: timer.heating_timer
  - platform: state
    entity_id: switch.house_boiler
    to: 'off'
  - platform: state
    to: 'on'
condition: []
  - choose:
      - conditions:
          - condition: trigger
        sequence:
          - service: timer.cancel
          - service: timer.start
              duration: '02:00:00'
      - conditions:
        sequence:
      - conditions:
        sequence:
          - choose:
              - conditions:
                  - condition: template
                    value_template: >-
                      {% set presence =
                      states('binary_sensor.livingroom_presence') %}
                      {{ presence == 'off' }}
                sequence:
                  - service: notify.tg_house_group
                      title: Heating Temperature Reset!
                      message: >
                        {% set ct =
                        state_attr('climate.lower_house','current_temperature')|float(0)
                        {% set tt =
                        state_attr('climate.lower_house','temperature')|float(0)
                        {% set nt = (ct - 0.4)|round(1) %}
                        The house heating has been running for longer than 2
                        hours!
                        The target temperature was {{ tt }}C and the current
                        temperature is now {{ ct }}C.
                        The new target temperature has been reset to {{ nt }}C
                  - service: climate.set_temperature
                      entity_id: climate.lower_house
                      temperature: >-
                        {% set ct =
                        %} {% set tt = (ct - 0.4)|round(1) %} {{ tt }}
            default:
                  duration: '00:15:00'
                  title: Heating Temperature Max Runtime!
                  message: >
                    {% set ct =
                    {% set tt =
                    state_attr('climate.lower_house','temperature')|float(0) %}
                    The house heating has been running for longer than 2 hours!
                    Presence was detected in the Living Room, so the timer has
                    been reset.
    default: []
mode: single
So the background to this, is that lately I have been waking up to find that the heating has been running for 6 hours overnight. Obviously this is expensive, but also pointless because if it hasn’t heated the house in 2 hours, it’s never going to. So I now have a timer that is started when the heating turns on, it is cancelled when the heating turns off. If however the timer reaches it’s 2 hour runtime (AND the livingroom is not occupied), then the target temperature is changed to the current temperature - 0.4C which ensures that the heating will turn off.
Because I use Schedy in appdaemon, the automatic temperature control will kick back in after 2 hours.
