@damru
How does your Hold on / Off selections look like on yours?
I tried different things and nothing seems to happen when I hold down the on and off button on my RODRET.
The same goes for the double and triple click
The pairing went fine and it looks like correctly exposed in Z2M.
But so far I have only been able to get the turn on and off feature to work.
Thanks for this. Love the simplicity. I would LOVE it though if you could choose the color temp too. I want the on function to always turn to a set brightness, and set temp (not the last color used)
Thanks for this! Generally it’s working fine for me, but there is a bug.
If I press the off button while my light is off, the light will turn on. Pressing the off button again will do nothing. I then have to press the on button before the off button will turn off the light.
It’s not a big problem for me because I know it, but guests could be confused if they accidentally turn on the light using the off button.
@damru great work! Only problem I’m having is when holding off button, it is dimming directly to 1% and dimming up goes very fast. Possible to slow down dimming speed? Using somrig.
I increased the timing between 2 steps from 0.05s to 0.1s. With the 5% brightness step, it should take ~2sec from 100% to 1%.
I could have exposed these 2 parameters, but I’d prefer to keep this blueprint as simple as possible.
If you want more flexibility, you could check my other blueprint IKEA RODRET Dimmer + SOMRIG Remotes - ZHA/Z2M - Control anything
v2.1.0
chore: use new yaml syntax
fix: turn off in control_light for zha e2201 by @leahoswald
feat(CL): increase dimming step delay from 0.05s to 0.1s
When holding down off button, dimming down starts but does not stop when releasing the button like it does when dimming up. I have to press down button again for it to stop. Is this on purpose?
Sorry I cannot debug ZHA at the moment.
Could you check your automation execution history, see if it is triggered when you release the button ? Basically it should be triggered and do nothing besides interrupting the previous execution (when holding down the button).
Also, do you have the same behaviour when holding down on button ?
When dimming up, command: long_release is registered in the execution history and the lights stop dimming up when releasing the ON button. When doing the same with the OFF button it does not trigger a command: long_release and the lights continue to dim down after releasing the button.
I’m using an IKEA Tradfri power supply connected to a smart outlet that operates on a schedule. The outlet powers my computer, monitors, and other equipment, including spotlights. It’s set to turn on at 7:30 AM and off at 4:30 PM daily.
The Tradfri power supply controls my spotlights using this blueprint and a Somrig remote. However, I’ve noticed that the spotlights always turn on automatically when the power is restored in the morning. I’d like to prevent this from happening and keep the spotlights off when the outlet turns on.
Does anyone have a suggestion on how to stop the spotlights from turning on automatically? Could this be something added to the code to prevent the spotlights from powering up when the outlet is restored each morning?
