Could this be fixed for the new Zigbee2MQTT update that doesn’t use actions any more?
Hi @ThaDuhFeez. I am planning to fix this eventually for the new Z2M update. However, I won’t have time until next week. I suggest you enable the actions and I will send an update when it is ready.
Hello, I have just updated the blueprint. It should now work with Zigbee2MQTT v2.0 since it uses mqtt device triggers. I noticed that it was slightly faster.
I am not sure if updating directly from home assistant will work. Therefore, you may have to delete and add the blueprint.
Also, I have not personally migrated to Zigbee2MQTT v2.0 so please report if it actually works.
Thanks for the update.
All I had to do was re-import the blueprint and recreate the automation with it.
I’m not sure about it being faster but it does work without issues.
However, while waiting for the update I finally broke down and tried making my own blueprint (using yours as a starting point) and got it working! So thanks for the update and the inspiration
@amorfinv, is your repo gone?
