I think it worked now, thanks
So went trough the whole update process and still on 1.0.024. Saw the update in the log till 100%. Must be doing something wrong.
2023-03-11 17:41:35.343 DEBUG (MainThread) [zigpy.zcl] [0xABBB:1:0x0019] OTA upgrade_end handler for 'IKEA of Sweden Remote Control N2': status=Status.SUCCESS, manufacturer_id=4476, image_type=4555, file_version=581
2023-03-11 17:41:35.344 DEBUG (MainThread) [zigpy.zcl] [0xABBB:1:0x0019] Sending reply header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=False, direction=<Direction.Client_to_Server: 1>, disable_default_response=1, reserved=0, *is_cluster=True, *is_general=False, *is_reply=True), tsn=1, command_id=7, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
2023-03-11 17:41:35.344 DEBUG (MainThread) [zigpy.zcl] [0xABBB:1:0x0019] Sending reply: upgrade_end_response(manufacturer_code=4476, image_type=4555, file_version=581, current_time=0, upgrade_time=0)
file_version=581 is this right?
I had to re-pair my device after update ' try that
Also follow this post afterwards to fix the battery showing as above 100%
Do we still need to apply this manual quirk workaround as of 2023.4 ?
Good question. My N2âs are now reporting 128% battery level. And the custom quirk is reporting exceptions.
Logger: zhaquirks
Source: custom_zha_quirks/fourbtnremote.py:44
First occurred: 25 April 2023 at 08:23:49 (1 occurrences)
Last logged: 25 April 2023 at 08:23:49
Unexpected exception importing custom quirk 'fourbtnremote'
File "/usr/local/lib/python3.10/site-packages/zhaquirks/__init__.py", line 454, in setup
importer.find_module(modname).load_module(modname)
File "<frozen importlib._bootstrap_external>", line 548, in _check_name_wrapper
File "<frozen importlib._bootstrap_external>", line 1063, in load_module
File "<frozen importlib._bootstrap_external>", line 888, in load_module
File "<frozen importlib._bootstrap>", line 290, in _load_module_shim
File "<frozen importlib._bootstrap>", line 719, in _load
File "<frozen importlib._bootstrap>", line 688, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 883, in exec_module
File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
File "/config/custom_zha_quirks/fourbtnremote.py", line 44, in <module>
from zhaquirks.ikea import (
ImportError: cannot import name 'PowerConfiguration2AAACluster' from 'zhaquirks.ikea' (/usr/local/lib/python3.10/site-packages/zhaquirks/ikea/__init__.py)
I fixed the 128% battery level and quirk exception issues by changing fourbtnremote.py, replacing all occurrences of âPowerConfiguration2AAAClusterâ with âDoublingPowerConfig2AAAClusterâ and restarting HA.
The modified custom_zha_quirks\fourbtnremote.py file is as follows:
"""Device handler for IKEA of Sweden TRADFRI remote control."""
from zigpy.profiles import zha
from zigpy.quirks import CustomDevice
from zigpy.zcl.clusters.general import (
Basic,
Identify,
LevelControl,
OnOff,
Ota,
PollControl,
PowerConfiguration,
from zigpy.zcl.clusters.lightlink import LightLink
from zhaquirks.const import (
CLUSTER_ID,
COMMAND,
COMMAND_HOLD,
COMMAND_MOVE,
COMMAND_MOVE_ON_OFF,
COMMAND_OFF,
COMMAND_ON,
COMMAND_PRESS,
COMMAND_STOP,
COMMAND_STOP_ON_OFF,
DEVICE_TYPE,
DIM_DOWN,
DIM_UP,
ENDPOINT_ID,
ENDPOINTS,
INPUT_CLUSTERS,
LEFT,
LONG_PRESS,
LONG_RELEASE,
MODELS_INFO,
OUTPUT_CLUSTERS,
PARAMS,
PROFILE_ID,
RIGHT,
SHORT_PRESS,
TURN_OFF,
TURN_ON,
IKEA,
IKEA_CLUSTER_ID,
WWAH_CLUSTER_ID,
DoublingPowerConfig2AAACluster,
ScenesCluster,
from zhaquirks import DoublingPowerConfigurationCluster
class DoublingPowerConfig2AAAClusterSTYRBAR_2_4_5(DoublingPowerConfigurationCluster):
"""Updating Power attributes 2 AAA."""
"""And for STYRBAR V2.4.5 as it scales battery voltage between 0-255."""
BATTERY_SIZES = 0x0031
BATTERY_QUANTITY = 0x0033
BATTERY_RATED_VOLTAGE = 0x0034
BATTERY_PERCENTAGE_REMAINING = 0x0021
_CONSTANT_ATTRIBUTES = {
BATTERY_SIZES: 4,
BATTERY_QUANTITY: 2,
BATTERY_RATED_VOLTAGE: 15,
def _update_attribute(self, attrid, value):
if attrid == self.BATTERY_PERCENTAGE_REMAINING:
value = (value / 255) * 100
super()._update_attribute(attrid, value)
class IkeaTradfriRemoteV1(CustomDevice):
"""Custom device representing IKEA of Sweden TRADFRI remote control V1.0.024."""
signature = {
# <SimpleDescriptor endpoint=1 profile=260 device_type=820
# device_version=1
# input_clusters=[0, 1, 3, 32, 4096, 64599]
# output_clusters=[3, 6, 8, 25, 4096]>
MODELS_INFO: [(IKEA, "Remote Control N2")],
ENDPOINTS: {
1: {
PROFILE_ID: zha.PROFILE_ID,
DEVICE_TYPE: zha.DeviceType.NON_COLOR_CONTROLLER,
INPUT_CLUSTERS: [
Basic.cluster_id,
PowerConfiguration.cluster_id,
Identify.cluster_id,
PollControl.cluster_id,
LightLink.cluster_id,
WWAH_CLUSTER_ID,
OUTPUT_CLUSTERS: [
OnOff.cluster_id,
LevelControl.cluster_id,
Ota.cluster_id,
replacement = {
ENDPOINTS: {
1: {
INPUT_CLUSTERS: [
Basic.cluster_id,
WWAH_CLUSTER_ID,
OUTPUT_CLUSTERS: [
ScenesCluster,
OnOff.cluster_id,
Ota.cluster_id,
device_automation_triggers = {
(SHORT_PRESS, TURN_ON): {COMMAND: COMMAND_ON, CLUSTER_ID: 6, ENDPOINT_ID: 1},
(LONG_PRESS, DIM_UP): {
COMMAND: COMMAND_MOVE_ON_OFF,
CLUSTER_ID: 8,
ENDPOINT_ID: 1,
PARAMS: {"move_mode": 0},
(LONG_RELEASE, DIM_UP): {
COMMAND: COMMAND_STOP_ON_OFF,
CLUSTER_ID: 8,
ENDPOINT_ID: 1,
(SHORT_PRESS, TURN_OFF): {COMMAND: COMMAND_OFF, CLUSTER_ID: 6, ENDPOINT_ID: 1},
(LONG_PRESS, DIM_DOWN): {
COMMAND: COMMAND_MOVE,
CLUSTER_ID: 8,
ENDPOINT_ID: 1,
PARAMS: {"move_mode": 1},
(LONG_RELEASE, DIM_DOWN): {
COMMAND: COMMAND_STOP,
CLUSTER_ID: 8,
ENDPOINT_ID: 1,
(SHORT_PRESS, LEFT): {
COMMAND: COMMAND_PRESS,
CLUSTER_ID: 5,
ENDPOINT_ID: 1,
PARAMS: {
"param1": 257,
"param2": 13,
"param3": 0,
(LONG_PRESS, LEFT): {
COMMAND: COMMAND_HOLD,
CLUSTER_ID: 5,
ENDPOINT_ID: 1,
PARAMS: {
"param1": 3329,
"param2": 0,
(SHORT_PRESS, RIGHT): {
CLUSTER_ID: 5,
ENDPOINT_ID: 1,
PARAMS: {
"param1": 256,
"param2": 13,
"param3": 0,
(LONG_PRESS, RIGHT): {
CLUSTER_ID: 5,
ENDPOINT_ID: 1,
PARAMS: {
"param1": 3328,
"param2": 0,
class IkeaTradfriRemoteV2(CustomDevice):
"""Custom device representing IKEA of Sweden TRADFRI remote control Version 2.4.5."""
signature = {
# device_version=1
# input_clusters=[0, 1, 3, 32, 4096, 64599, 64636]
# output_clusters=[3, 5, 6, 8, 25, 4096]>
ENDPOINTS: {
1: {
INPUT_CLUSTERS: [
Basic.cluster_id,
WWAH_CLUSTER_ID,
IKEA_CLUSTER_ID,
OUTPUT_CLUSTERS: [
ScenesCluster.cluster_id,
OnOff.cluster_id,
Ota.cluster_id,
replacement = {
ENDPOINTS: {
1: {
INPUT_CLUSTERS: [
Basic.cluster_id,
DoublingPowerConfig2AAAClusterSTYRBAR_2_4_5,
WWAH_CLUSTER_ID,
IKEA_CLUSTER_ID,
OUTPUT_CLUSTERS: [
ScenesCluster,
OnOff.cluster_id,
Ota.cluster_id,
device_automation_triggers = IkeaTradfriRemoteV1.device_automation_triggers.copy()
Hey there,
How did you manage to fix this error?
Iâve got the same problem, but waking up the remote from sleep before issuing the command isnât working for me.
Managed to finally fix it through trial and error.
I think taking the batteries out of the remote and putting them back in made the remote accept the OTA, almost like a hard reset.
If for some reason the first attempt after putting the batteries in failed or abruptly pauses during the update, then I had to take the batteries out and put them back in again, otherwise Iâd just get that error over and over.
