I’ve never had luck listening for “zha_events”. Try listening for all events “*” instead, and see if you get it. (You’ll be flooded with events, though.)
-David
All my Ikea buttons of this type just stopped working yesterday. Coincidently after I upgraded to the new HA release. I wonder if something broke due to the new release. I get the exact same behavior, where the buttons do properly bind, but button presses are no longer being registered. I am using the Sonoff Zigbee dongle, with the latest coordinator FW (CC1352/CC2652, Z-Stack 3.30+ (build 20221226)). and using ZHA.
I tried removing, rebinding, rebinding directly to the coordinator, rebinding via a router device, reconfiguring after binding, … No luck so far. The button presses no longer come through. Nothing noteworthy appears in the logs. If someone has any ideas?
EDIT: Seems indeed something broke in the latest HA release. Devs seem to be aware and are working on it.
Yep, am using the latest coordinator firmware, I also switched my sonoff coordinator to the home assistant sky connect adapter using the built in backup / migrate radio.
All other devices work, tried removing, re-adding, re-configuring the ikea switch, not a whisper, nothing detected whatsoever on button presses from this device.
I suspect others will start discovering that this no longer works in the latest releases.
For me, they started working again in release 2023.4.2. The ones I never tried to repair after installing 2023.4.0 just resumed working without any intervention. The 2 I started playing with when they stopped working somehow didn’t. I had to remove those 2 devices from ZHA, rebooted my whole HA instance, and then just repaired them. They started working again.
Hope it works for you as well.
For me they stopped working with the update of Z2M today. I can see the actions still if I am checking it from the Z2M page, but not in HA. Tried deleting the device and adding again, but no luck. Hopefully a new update will solve this.
Did you read the release notes?
Yes I just did, thanks tho. Unfortunately I use node red. And listening to events can be done, but it is very cumbersome… So I switched back to legacy actions for now.
