Ikea Tradfri Push Button
OK, event received now!
Indeed, it is “deconz_event” to listen to, without ‘s’
Now received this event:
    "event_type": "deconz_event",
    "data": {
        "id": "tradfri_on_off_switch",
        "unique_id": "5c:02:72:ff:fe:80:4c:b9",
        "event": 1002,
        "device_id": "a222ef86f483ab4aaeec1a350bcd65f8"
    "origin": "LOCAL",
    "time_fired": "2021-02-15T10:18:32.615694+00:00",
    "context": {
        "id": "513cf3e0557bbf1106f1dd5f42d9b5a6",
        "parent_id": null,
        "user_id": null
Thank you for your help
Perfect.
Here’s the yaml way to do the trigger:
event_data:
  event: 1002
event_type: deconz_event
platform: event
Or see pic for the UI method
Hey all,
I’ve purchased the Ikea button, but I cannot add it to my Pi3b+ running deCONZ\Phoscon Stable Ubuntu image.
The button does not appear in Phoscon when adding as Switch\Other. In deCONZ (graphic user interface over VNC) there is a device showing only the network address and device address. I am unable to change the name of the device.
I’ve also connected node-red to deCONZ, pressing the button does not generate a message whereas other devices (ikea round multi-button, aqara cube) do.
Version : 2.07.01 / 08/12/2020
Anyone having the same problem? Or a pointer to a solution perhaps?
Thanks very much!
Same problem
Im currently on version 2.09.03 / 23.12.2020
Firmware 26660700
