Hi, I’m trying to setup both ili9341 screen (exactly waveshare 18366) and W5500 to work simultaneously, although I’m facing some issue, so would love some community help in understanding where I’m making a mistake.
My device is ESP32S3 n16r8 devkit. Interestingly both devices set-up separately work perfectly fine. So either LCD screen with Wifi config or W5500 connected via cable but w/o the screen.
On top of that when both devices are set-up ESP seems to boot correctly and operate fine, but w/o Ethernet connectivity and screen being blank.
Doesn’t seem to be power issue as well as I have external power source for this setup that should easily handle this.
P.S. By them working correctly when connected separately, I meant that both are still physically connected, but disabled in config, so seems like software related issue
Thanks for the tips! I was able to successfully setup PSRAM, but the issue remains.
So both modules work fine when configured separately, but when both are enabled in config they both fail to boot.
I cannot even access logs via usb (logger is stuck at init).
What’s interesting is that I have switch that switches on board LED and this part of program is working correctly…
My guess is that it’s something wrong with SPI config, but trying different options doesn’t really help. I guess that I’m lacking something very basic in how SPI and W5500 SPI are configured by ESPHOME
Update:
Changing screen’s SPI bus interface to software did help a bit, ESP is booting up with both devices operational, but… performance is terrible, so poor that ESPHOME API is unusable
That’s proof’s issue has something to do with how SPI gets init in this situation, but how to configure that to use to separate hardware SPIs, no idea… Software SPI is not an option long-term
Oh, you might find the W5500 is claiming a specific SPI interface, and not playing nicely with other SPI devices - I’d guess it’s not using the SPI hub component. Try specifying the hardware SPI interface for the display to be SPI3.
Ok, so changing interface to SPI3 did help, but with some additional changes. I had to change framework to esp-idf as well and everything started to work correctly.
Seems like there is a bug somewhere with initialisation of SPI buses with Ethernet component when using arduino framework.
Pasting my final config for reference if anyone faces similar issue in the future:
