Vayain
(Vayain)
April 7, 2017, 9:36pm
21
Hi mplawner,
thanks a lot for looking back in you script, appreciate it!
I tried as you suggested - using “parseemail.sh TEST-BACKUP FAIL” manually works find and the sensor switches to “Failed”.
So - the automation rule it is…
I looked into the mails, “TEST-Backup FAIL” for example is placed in the mail body…but the trigger won’t act.
So the issue seems to be the missing value from the automation to the script - i understood.
Tried {{ states(‘sensor.emails’) }} too, sadly with the same result.
- alias: Email State Change - Parse
- platform: state
entity_id: sensor.emails
- service: shell_command.parseemail
data_template:
#value: "{{ state('sensor.emails') }}"
value: "{{ trigger.to_state.state }}"
So close
mplawner
(Michael Plawner)
April 8, 2017, 2:27pm
22
The script is case sensitive, so if you have “TEST-Backup FAIL” in the body, but TEST-BACKUP FAIL in the script, those two values won’t be equal.
Have you tried sending emails manually?
Vayain
(Vayain)
April 19, 2017, 8:08am
23
Thanks mplawner! Sorry for the delay, had to sort out some private stuff.
And guess what, with a fresh view, there is my ‘Ah Ha’ moment
Incoming mails are processed via imap_email_content, the content is shown in sensor.emails and your wonderful script parses the content according to the rules and feeds mqtt. Thanks again for sharing your work!
There seems to be a difference between “value: “{{ states (‘sensor.emails’) }}”” and “value: “{{ state (‘sensor.emails’) }}””, that did it for me.
parseemail: bash /home/homeassistant/.homeassistant/parseemail.sh {{value}}
parseemail.sh
#!/bin/sh
echo "****" >> /home/homeassistant/.homeassistant/parseemail.log
echo $1 >> /home/homeassistant/.homeassistant/parseemail.log
if [ $# -ne 1 ]; then
echo "Unknown"
else
# Backup Status Sycloud TEST 3
mosquitto_pub -h 127.0.0.1 -u <User> -P <PW> -r -t RaspHA/emails/`echo $1 | awk '/SyCloud/ {print "Backup_TEST3"}'` -m "SyCloud"
mosquitto_pub -h 127.0.0.1 -u <User> -P <PW> -r -t RaspHA/emails/`echo $1 | awk '/SxCloud/ {print "Backup_TEST3"}'` -m "SxCloud"
fi
Automation - email_parse.yaml
- platform: state
data_template:
value: "{{ states('sensor.emails') }}"
Sensor MQTT
- platform: mqtt
name: "MQTT Status Backup TEST3"
state_topic: "RaspHA/emails/Backup_TEST3"
mplawner
(Michael Plawner)
April 19, 2017, 1:56pm
24
Whew! Glad you got there @Vayain and all is working for you!
I’m still uncertain why
works for you and
doesn’t. They should be the same.
Nonetheless, glad you’re up and running!
Vayain
(Vayain)
April 19, 2017, 6:49pm
25
Thanks to you
Giving it another try with “trigger.to_state.state”, the result is the same…I’m wondering, where my first error was…
Now i recognized one last thing…seems like the parsing uses only the first word:
parseemail.log
TEST-BACKUP
Backup_SyCloud-2-WDextern
Backup_SyCloud-2-SGextern
TEST-BACKUP
For example the last entry should be “TEST-BACKUP FAILED”, the state of “sensor.email” is complete, seems like something got lost somewhere
mplawner
(Michael Plawner)
April 19, 2017, 9:39pm
26
Odd. My script does appear to be parsing the full message.
For example, from my log:
4/19 5:03 PM
Garage Door (Zone 12) changed to Open.
garagedooropen
4/19 5:04 PM
Garage Door (Zone 12) changed to Closed.
garagedoorclosed
Those entries were accurately captured by the following lines from the script:
# Garage Door
mosquitto_pub -h 127.0.0.1 -r -t home-assistant/emails/`echo $1 | awk '/garagedooropen/ {print "garagedoor"}'` -m "open"
mosquitto_pub -h 127.0.0.1 -r -t home-assistant/emails/`echo $1 | awk '/garagedoorclosed/ {print "garagedoor"}'` -m "closed"
I confirmed my current script is as described above.
mplawner
(Michael Plawner)
April 19, 2017, 9:42pm
27
I should also mention, I’m running Home Assistant 0.42.4 (current) on a Raspberry PI 3, pip install (no docker).
