Hi all,
Can I import a macro into a template sensor? I can’t see any documentation saying you can and I am aware that you can import directly into an automation.
TL;DR
I have a bunch of template sensors - one for each of my shades - that look a lot like this:
template:
- sensor:
- name: "Bedroom 1 shade"
unit_of_measurement: "%"
state: >
{% set open = states('binary_sensor.bedroom_1_window_contact') %}
{% set sun = states('binary_sensor.shades_south_has_sun') %}
{% set light = states('sensor.light_level') %}
{% set house = states('input_select.house_mode') %}
{% set uv = states('sensor.weather_uv_index')|float(0) %}
{% set t_in = states('sensor.hottest_temp')|float(15) %}
{% set t_out = states('sensor.weather_temp')|float(15) %}
{# window closed #}
{% if open == 'off' %}
{% if light == 'Night' or house == 'Asleep' %} 0 {# eve / asleep #}
{% elif t_out >= 24 and uv >=6 and sun == 'on' %}
{% if t_in >= 24 %} 0 {# day, h UV, sun on, h temp #}
{% elif t_in >= 22 %} 50 {# day, h UV, sun on, m temp #}
{% else %} 100 {# day, h UV, sun on, l temp #}
{% else %} 100 {# day, l UV #}
{# window open #}
{% elif light == 'Night' or house == 'Asleep' %} 50 {# eve / asleep #}
{% if t_in >= 22 %} 50 {# day, h UV, sun on >=m temp #}
It returns the position
(0-100) to set my shade to based on temp, UV, whether the associated dr/window is open or not etc etc.
They are all almost exactly the same (except for the contact sensor). I would very must like to change those sensors to this:
- name: "Bedroom 1 shade test"
state: >
{% from `shade.jinja` import south_shade_level %}
{{ south_shade_level(binary_sensor.bedroom_1_window_contact) }}
and have a single macro looking something like this:
{% macro south_shade_level(contact) %}
{% set open = states(contact) %}
{# window closed #}
{# window open #}
{% endmacro -%}
This would help me make global changes as there code only exists once. Does anyone know if this is even possible?
