REFUSED should be honoured as well, this response (usually) means the request is blocked for policy reasons, and this should not be passed to a ‘fallback’.
Also, once a fallback request has been initiated, it never stops trying to resolve this query even when the main DNS is online, and the more these requests get blocked the more it sends.
So, I have AdGuard on HA which is doing DNS blocking running on a platform that is doing its best to circumvent DNS blocking…
Didn’t know that, I thought that was related to network/auth issues. Like if the server was configured to only listen to requests from specific IP addresses and HA’s wasn’t one of them. I agree then, that shouldn’t fallback either.
Tried again to raise this issue and it just gets closed by devs. One of my biggest pet peeves of HA devs is they way they close ticket with:
A) no explanation
B) Working on it but not resolved - it shouldn’t be set to closed until it’s resolved.
Whats worse, Coredns keeps breaking.
I have a secured network where all dns/dot/… is blocked,
After a few hours coredns ‘forgets’ the dns server assigned,
and just stops resolving completely, as it can’t reach cloudflare.
Even tried the other way round to finally fix this:
set up my own dot forwarding provider, +redirect rules
(nginx streaming dns over ssl).
I fell into this hassio core-dns rabbit hole a few days ago. I never had name resolution problems with HA. TBH I didn’t even know HA is using it’s own dns until then. In my case this seems to be triggered by switching from a “dnsmasq classic” name server to pihole for local name resolution. Since then, ha-dns seems to be regularly failing to do proper name resolution for local hosts after some time and is stuck with the hardcoded cloudflare dns until the dns container is restarted.
I don’t know, why ha-dns seems to be so finicky about this change. Maybe pihole is answering DNS requests a bit more slowly…? Or just because? I don’t know.
Unreliable name resolution in a local network, that is well-curated with proper host names and static dhcp leases is a huge PITA. Failing name resolution virtually breaks everything. In the worst case it’s leading to me sitting next to the broken DNS server with a laptop connected directly via ethernet cable and debugging it, because even wifi access points stop working properly after a couple of minutes when name resolution is down.
Because of that I’m deliberately running two name servers with failover functionality in my local network to avoid a SPOF for name resolution. HA breaks this redundancy by insisting of using it’s own nameserver. If that breaks, a lot of things in HA are going sideways, even HA core functionality like writing values to the recorder and influxdb databases.
Quite surprised about this, bad practice for sure, I see devs doing this type of thing more and more. Firefox is trying to bypass DNS using DoH, Systemd had a similar incident. Same attitude I read here from devs who never managed and/or tried to secure a network. Would be great if HA respects the local network settings.
Cloudflare is a perfectly reasonable DNS provider but forcing people to use it is not.
In the unlikely event cloudflare goes down you’re screwed. (Probably not because cache would last until they came back but still) It does happen sometimes.
Main issue for me is that you should never override the dhcp by default. This breaks stuff and is a security issue. With Firefox wanting DoH to be enabled by default this would break resolution in split dns environments. So for instance if a user connects their device with Firefox with default DoH enabled on a network I manage they cannot access internal webmail, chat etc.
Also regarding Cloudflare, Americans are somewhat protected from spying at the endpoint, the rest of the world are not.
For some reason they consider having it not hard coded a feature. People who point out the error that it is are demanding a feature. Just mark it as the bug it is and fix it when you can I would think.
I live on a sailboat. I use HA to control various things aboard the boat. Right now, I have full Internet access. When I go offshore, I’m not going to have access to anything outside of my little network.
Having a (breaking) reliance on external DNS is a travesty.
Hi, I’m new to Home Assistant . I installed the VM to test it and the first thing I noticed was how it was hammering my edge firewall non stop trying to reach CloudFlare DoT servers.
I read the thread and all the issues posted and is sad to see the Devs do not consider this as a bug.
Hardcoding DNS is a no-go and is difficult to imagine a reason rather than to simplify the development. If that was the case they should not close the issues and leave them opened for future improvements.
My current solution is to block traffic to 1.1.1.1 and 1.0.0.1 at the host using iptables. Is a hack and this does not survive a reboot but so far it works. I guess I could make it persistent but I want to test it for some days first.
I did a quick look a the DNS docker and could not find the obvious source of the requests. If someone knows I’d like to get a pointer because I would prefer to point this to my own servers rather than blocking them.
If someone wants to do the same is very simple. Use the “SSH & Web Terminal” addon to SSH to the host and then execute the following:
As you can see all requests are sent to my local server (192.168.1.3) but also to a local instance in the port 5553. This local instance will send all request plus any that the local DNS server rejects, to Cloudflare using TLS over DNS.
Basically is an anti “pi-hole” feature. It does not matter if you filter your local DNS because your filters are always bypassed using CF unless you block the port 853 in your edge firewall.
I confirmed that if I change the 1.1.1.1 to another IP the request change
