too fast, I found the configuration file in /etc/corefile
bash-5.1# vi /etc/corefile
.:53 {
log {
class error
errors
loop
hosts /config/hosts {
fallthrough
template ANY AAAA local.hass.io hassio {
rcode NOERROR
mdns
forward . dns://192.168.1.3 dns://192.168.1.3 dns://127.0.0.1:5553 {
except local.hass.io
policy sequential
health_check 1m
fallback REFUSED,SERVFAIL,NXDOMAIN . dns://127.0.0.1:5553
cache 600
.:5553 {
log {
class error
errors
forward . tls://1.1.1.1 tls://1.0.0.1 {
tls_servername cloudflare-dns.com
health_check 5m
cache 600
As you can see all requests are sent to my local server (192.168.1.3) but also to a local instance in the port 5553. This local instance will send all request plus any that the local DNS server rejects, to Cloudflare using TLS over DNS.
Basically is an anti “pi-hole” feature. It does not matter if you filter your local DNS because your filters are always bypassed using CF unless you block the port 853 in your edge firewall.
I confirmed that if I change the 1.1.1.1 to another IP the request change
