Hey, I’ve been trying to get this component to work on my hass as well. However, I cannot get example.py of wideQ to give me a working output.
Anyone has an idea what I is going wrong here?
This is the error output example.py returns:
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 343, in _make_request
self._validate_conn(conn)
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 841, in _validate_conn
conn.connect()
File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 344, in connect
ssl_context=context)
File "/usr/lib/python3/dist-packages/urllib3/util/ssl_.py", line 344, in ssl_wrap_socket
return context.wrap_socket(sock, server_hostname=server_hostname)
File "/usr/lib/python3.7/ssl.py", line 412, in wrap_socket
session=session
File "/usr/lib/python3.7/ssl.py", line 853, in _create
self.do_handshake()
File "/usr/lib/python3.7/ssl.py", line 1117, in do_handshake
self._sslobj.do_handshake()
ssl.SSLError: [SSL: UNSUPPORTED_PROTOCOL] unsupported protocol (_ssl.c:1056)
File "/usr/lib/python3/dist-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/lib/python3/dist-packages/urllib3/util/retry.py", line 398, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='aic.lgthinq.com', port=46030): Max retries exceeded with url: /api/member/login (Caused by SSLError(SSLError(1, '[SSL: UNSUPPORTED_PROTOCOL] unsupported protocol (_ssl.c:1056)')))
File "example.py", line 225, in <module>
main()
File "example.py", line 221, in main
example(args.country, args.language, args.cmd, args.args)
File "example.py", line 181, in example
example_command(client, cmd, args)
File "example.py", line 157, in example_command
func(client, *args)
File "example.py", line 26, in ls
for device in client.devices:
File "/home/homeassistant/.homeassistant/custom_components/smartthinq/wideq/wideq/client.py", line 123, in devices
self._devices = self.session.get_devices()
File "/home/homeassistant/.homeassistant/custom_components/smartthinq/wideq/wideq/client.py", line 114, in session
self._session, self._devices = self.auth.start_session()
File "/home/homeassistant/.homeassistant/custom_components/smartthinq/wideq/wideq/core.py", line 273, in start_session
self.gateway.country, self.gateway.language)
File "/home/homeassistant/.homeassistant/custom_components/smartthinq/wideq/wideq/core.py", line 191, in login
return lgedm_post(url, data)
File "/home/homeassistant/.homeassistant/custom_components/smartthinq/wideq/wideq/core.py", line 120, in lgedm_post
res = requests.post(url, json={DATA_ROOT: data}, headers=headers)
File "/usr/lib/python3/dist-packages/requests/api.py", line 116, in post
return request('post', url, data=data, json=json, **kwargs)
File "/usr/lib/python3/dist-packages/requests/api.py", line 60, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python3/dist-packages/requests/adapters.py", line 514, in send
raise SSLError(e, request=request)
requests.exceptions.SSLError: HTTPSConnectionPool(host='aic.lgthinq.com', port=46030): Max retries exceeded with url: /api/member/login (Caused by SSLError(SSLError(1, '[SSL: UNSUPPORTED_PROTOCOL] unsupported protocol (_ssl.c:1056)')))
