Is there any way to program the installation settings on an LG CRC thermostat?
Specifically, things like deadband and display settings?
I mean remotely — using the API.
Thank you!
Thank you!
Hi, I have a washer/dryer but among the sensors I seem to only find those relating to the washing machine. I only have a dry_level Could it be a component problem?
How can we monitor energy/power consumption on my Washer Dryer? I’m able to view it in the ThinQ app, but the integration doesn’t expose anything under the sensors.
Hello world,
Hope THIS is the right place…
I succesfuly installed @ollo69 's SmartThinQ LGE Sensors (V0.37.0) through HACS in order to control my airco units from HA.
When adding the integration in the Devices & services/integrations tab and submitting the required configuration information, I get a ‘Invalid SmartThinQ credentials’ error.
I have used a private email address for my LG registration as stated, and accepted all license and privacy agreements in the LG app and on the website.
Also, the LG ThinQ apps works fine, controlling my 3 airco units.
I did the LG app registration and configuration from the Netherlands, thus using country code Netherlands-NL and language Dutch-nl and verified those in the LG app.
I tried the given SmartThinq login URL to see if redirection works, but am not able to generate a working redirect URL because of an internal server error. So, dead end on the LG side (my normal account logins through https://www.lg.com/nl are OK).
I found a lot of open ends in this and other threads, so trying a new post.
Hope you can be of help!
As I am still a HA rooky please adjust your answer to my level.
HA Core 2024.1.6
HA OS 11.4
I read the logs before sending over. Showed an SSL error.
It seems that the LG domain nl.emp.lgsmartplatform.com was filtered out by OpenDNS.
Whitelisted the URL and airco units are now recovered.
[Close]
