Thank you, I appreciate your help a lot.
I have a working automation now and learned new things.
For future reference:
I used the suggested code with the triggers as a value template.
Unfortunately the automation also triggers when just one condition is met.
Both conditions/triggers need to be met before it should activate.
Is there a way to alter the code to accomplish this?
Can I copy/paste the code from the triggers in conditions?
alias: Luchtverversing AAN (Temp/Hum) (Template)
description: ""
value_template: >-
{{ states('sensor.werk_temp') | float(0) > states('sensor.cp_temp') |
float(0)
and states('sensor.werk_humi') | float(0) > states('sensor.cp_humi') | float(0) }}
condition: []
- type: turn_on
device_id: 102103dc3ec38e21c9c878478ca2bde0
entity_id: switch.droger_stopcontact
domain: switch
- type: turn_on
device_id: 58913d5702500b426a217c63eb1b979d
entity_id: switch.lucht_toevoer
domain: switch
- device_id: 665e1de5daaaedefd9e0e553a5b0249e
domain: mobile_app
type: notify
message: Luchtverversing AAN (Temp/Hum) (Template)
mode: restart
If you mean this (shown below) then the two Numeric State Conditions are implicitly ANDed. It means both must evaluate to true
in order for the automation to execute the actions. If one of the two evaluates to false
then it terminates (no actions are executed).
condition:
- condition: numeric_state
entity_id: sensor.werk_humi
above: "{{ states('sensor.cp_humi') | float(0) }}"
entity_id: sensor.werk_temp
above: "{{ states('sensor.cp_temp') | float(0) }}"
If you doubt it, examine the automation’s trace and it will show both conditions reported true
(for the actions to be executed).
But isn’t these conditions the same as the template trigger he posted?
There shouldn’t be a need for conditions
If I understood RickyM’s comment correctly, he claimed:
If condition
contains two State Conditions (as shown above) then both must be true
, not just one, for action
to be executed.
If RickyM was referring to some other conditions then I misunderstood the comment.
I believe it was wrongly worded.
The “conditions” was the two states in the template trigger.
I see. I thought RickyM’s comment was about the two State Conditions in the original example (i.e. the example you had suggested). Because, after claiming it triggers when only one State Condition is met, he posts a new example that incorporates the State Conditions from the original example directly in a Template Trigger.
I’m sorry if I caused confusion. I’m also confused now
The below code has two triggers as a value template, no conditions.
If one of the two triggers is true the automation will activate.
description: ""
value_template: >-
float(0)
condition: []
- type: turn_on
domain: switch
- type: turn_on
domain: switch
domain: mobile_app
type: notify
mode: restart
The automation should only activate when both triggers are true.
How can I alter this code to accomplish this?
Can I just copy/paste the code from the trigger section in the condition section?
Like this:
description: ""
value_template: >-
float(0)
condition:
value_template: >-
float(0)
- type: turn_on
domain: switch
- type: turn_on
domain: switch
domain: mobile_app
type: notify
mode: restart
It shouldn’t, it’s not two triggers, it’s one trigger with four entities in a template combined with an and.
Because there is an and
it should only trigger when both parts are true.
It would be interesting to see the trace when it triggered.
It could actually be that because the float filter defaults to 0, if there was a brief unknown value then it could trigger.
If cp_temp and cp_humi was unknown they got defaulted to 0 and that would probably make it trigger
That wouldn’t work.
If it passed the trigger then it would pass the condition also.
This is what I find in the trace.
I can’t see any mention of sensor.cp_temp, sensor.werk_humi and sensor.cp_humi
Triggered by the sensor.werk_temp via template at August 31, 2022 at 10:43:02
turn_on Lucht afzuiging
turn_on Lucht toevoer
2 seconds later
notify undefined
Finished at August 31, 2022 at 10:43:04 (runtime: 2.15 seconds)
this:
entity_id: automation.luchtverversing_aan_temp_hum_2
state: 'on'
attributes:
last_triggered: '2022-08-31T08:40:22.068397+00:00'
mode: restart
current: 0
friendly_name: Luchtverversing AAN (Temp/Hum) (Template)
last_changed: '2022-08-30T19:58:50.555577+00:00'
last_updated: '2022-08-31T08:40:22.109038+00:00'
context:
parent_id: 01GBSGXZ91E2WN1CZEDH6Z9W5Q
user_id: null
platform: template
from_state:
state: unavailable
attributes:
state_class: measurement
unit_of_measurement: °C
device_class: temperature
friendly_name: Werk Temp
last_changed: '2022-08-31T08:42:58.653725+00:00'
last_updated: '2022-08-31T08:42:58.653725+00:00'
context:
parent_id: null
user_id: null
to_state:
state: '24.2'
attributes:
last_changed: '2022-08-31T08:43:02.549858+00:00'
last_updated: '2022-08-31T08:43:02.549858+00:00'
context:
parent_id: null
user_id: null
idx: '0'
for: null
description: sensor.werk_temp via template
This is interesting.
Are these sensors often offline?
I never notice they are unavailable.
I have an entity card with all the temp sensors on my home page to visually monitor this, so that I should maybe move my esp32’s to another spot if entities will get unavailable.
But I’m not always looking at this screen, so it could be.
Is there some test I can do that runs in the background for a set time, where I can see in a log if there’s a time where it’s offline?
You could probably use the ‘{{ trigger.to_state != unavailable}}’
And on the from states, as condition in the automation.
But I believe, someone please correct me if I’m wrong, the previous automation we had with two triggers and two conditions does not trigger on unavailable.
Perhaps it’s easier to just use that automation
I’m not sure what you mean or how I can use this information.
Do you mean this one?
condition:
Can I implement it like this?
description: ""
value_template: >-
float(0)
condition:
- type: turn_on
domain: switch
- type: turn_on
domain: switch
domain: mobile_app
type: notify
mode: restart
I meant both the triggers and the conditions.
Ok, thank you!
I’m going to test this one.
Ow, this one had the issue that it’s not allowed to use templates in conditions.
I get this error message:
Message malformed: expected float for dictionary value @ data[‘condition’][0][‘above’]
Then you came with the solution to use a value template as trigger. This should work, but in my case didn’t because a sensor was unavailable. If I understood you correctly.
So I need to solve the sensor issue or somehow prevent that the automation triggers when a sensor is unavailable.
I think you where referring to this with the following comment, but I don’t understand what you wrote there.
