Increase or decrease light brightness over time
You could also make that delay user-configurable like this:
blueprint:
  name: Increase light brightness over time
  description: |
    # Increase light brightness over time
    This script increases the brightness of a light over time.
    Given the **transition time**, **initial brightness**, **target brightness** and **brightness step**, the script will calculate the number of steps required to reach the target brightness and the delay between each step.
    The script will then turn on the light with the initial brightness, wait 5 seconds and then start increasing the brightness by the brightness step every delay between steps until the target brightness is reached.
    ```text
                     100% ┌───────────────────────────────────────────────────────────────────────────────────────────────────┐
                          │        ┌─────────┤ ◄ target brightness
                          │                   calculated delay                  │                                             │
                          │                 │ ◄──────────── brightness step                                                   │
    initial brightness    ├─────────────────┘        │
                       0% └───────────────────────────────────────────────────────────────────────────────────────────────────┘
                          0s        transition time
    ### Calculations
    _steps = (target brightness - initial brightness) / brightness step)_
    _delay = transition_time / steps_
  domain: script
  author: op00
  source_url: https://community.home-assistant.io/t/increase-light-brightness-over-time/600349
  input:
    light_entity:
      description: "Select the target Light\n\n
                    _single entity_"
      selector:
        entity:
          filter:
            domain: light
          multiple: false
    transition_time:
      description: "Select the transition time\n\n
                    _min is 100 seconds, max is 3600 seconds = 1 hour_"
      default: 100
      selector:
        number:
          min: 100
          max: 3600
          step: 1
          unit_of_measurement: seconds
          mode: slider
    target_brightness:
      name: Target Brightness
      description: "Select the target brightness\n\n
                    _default is 100%_"
      default: 100
      selector:
        number:
          min: 0
          max: 100
          step: 1
          unit_of_measurement: '%'
          mode: slider
    initial_brightness:
      name: Initial Brightness
      description: "Select the initial brightness\n\n
                    _default is 10%_"
      default: 10
      selector:
        number:
          min: 0
          max: 100
          step: 1
          mode: slider
    brightness_step:
      description: "Select the brightness step\n\n
                    _default is 2%_"
      default: 2
      selector:
        number:
          min: 2
          max: 100
          step: 1
          mode: slider
    initial_delay:
      description: "Select the delay before starting the transition in milliseconds\n\n
                    _default is 5000ms (5 seconds)_"
      default: 5000
      selector:
        number:
          min: 0
          max: 10000
          step: 100
          mode: slider
icon: mdi:lightbulb-on-60
variables:
  transition_time: !input transition_time
  brightness_step: !input brightness_step
  initial_brightness_pct: !input initial_brightness
  target_brightness_pct: !input target_brightness
  light_entity: !input light_entity
  initial_delay: !input initial_delay
  - variables:
      target_brightness: '{{(target_brightness_pct * 255 / 100)|round}}'
      initial_brightness: '{{(initial_brightness_pct * 255 / 100)|round}}'
      required_steps: '{{(((target_brightness_pct - initial_brightness_pct) / brightness_step))|round|int}}'
      delay_between_steps: '{{ (transition_time / required_steps)|round|int }}'
  - service: light.turn_on
      brightness: '{{ initial_brightness }}'
      transition: 0
    entity_id: !input light_entity
  - delay:
      hours: 0
      minutes: 0
      seconds: 0
      milliseconds: {{initial_delay}}
  - repeat:
      while:
        - condition: template
          value_template: '{{ state_attr(light_entity, "brightness") | int < target_brightness }}'
            transition: 0
            brightness_step_pct: '{{ brightness_step }}'
        - delay:
            hours: 0
            minutes: 0
            seconds: '{{ delay_between_steps }}'
            milliseconds: 0
Sorry if formatting is screwed up, did it on my phone…
