InfluxDB vs VictoriaMetrics
I’m using VictoriaMetrics in combination with Home Assistant for a couple of months now, and I am pretty pleased with it. It runs very stable, and the database size remains within limits. I run both HA and VM in docker containers, and wanted to share my configuration for those who would like to run the same, or a similar setup.
Here is my docker compose file to start the VM service, and to have the VM data stored in an external data container:
services:
  victoriametrics:
    container_name: victoriametrics
    image: victoriametrics/victoria-metrics:latest
    ports:
      - 8428:8428
    volumes:
      - vm-data:/victoria-metrics-data
    command:
      - "--retentionPeriod=99y"
    restart: unless-stopped
volumes:
  vm-data:
    external: true
I use the influxDB integration of HA to write to the VM database, so I don’t need a VM agent and prometheus configuration. Note that I do not use an Influx database, I only use the HA integration. In my configuration.yaml file I have added:
influxdb:
  api_version: 1
  host: <host_ip_adres>
  port: 8428
  measurement_attr: entity_id
  tags_attributes:
    - friendly_name
    - unit_of_measurement
  include:
    domains:
      - binary_sensor
      - climate
      - counter
      - cover
      - light
      - sensor
      - switch
That’s it. In Grafana I can now choose to use the VM database as InfluxDB Timeseries Database, or as Prometheus Timeseries Database, or both. Both work, but use a different query language.
I have about 1000 HA entities, and my VM database grows about 1 MB per day.
@CreebleHoost , thanks for sharing your configs! They look great except one thing - it is better to specify a particular release tag for victoriametrics instead of latest, since the latest tag may point to some testing release. For example, it is much better to use v1.90.0 instead of latest. It is also recommended periodically checking VictoriaMetrics changelog for new releases.
This is a very important point and actually one of the inspirations of this thread.
Thanks, that is a good suggestion. Ideally there would also be a stable release tag. Then I would get the release with the latest fixes, without running the risk of getting experimental code.
Typically I don’t check manually if there are new stable releases available. Not only for VM, but for any docker.
VictoriaMetrics already provides stable Docker image tag for new releases - see this comment.
Note that it is recommended to do periodic docker pull for upgrading VictoriaMetrics Docker image to the latest stable release.
@chintito4ever
For migrating your influxdb data you should use the vmctl tool from victoria metrics. You can use it on your host or any other linux machine.
In this thread you might find some hints using it:
The bug i posted is sorted out and it runs without any errors even if you have empty measurements.
Using the config suggested above, I’m getting ..._value and a ..._state metric for each binary_sensor when looking at the data via Grafana (using the VictoriaMetrics plugin for connection). And a light goes between 1 and 0 for on vs off. Is this by design or a misconfiguration on my part? Is there a way to have the actual states (occupied, on, etc) tracked? I also don’t see the UX to do things like aggregate (e.g., average for each hour, etc). Perhaps user error here?
  tags_attributes:
    - friendly_name
I am currently using InfluxDB, and my DB is growing in size very fast, so I am looking for a long-term solution to this issue.
Can anyone maybe provide some comparison info on the size of the DB, or the expected size reduction when using VictoriaMetrics instead of InfluxDB?
Also, is there a downsampling feature in VictoriaMetrics for HA? Their official gitHub states it is available in VM Enterprise only…
Thanks!
I have a fundamental question concerning the feeding of measurements to VM if using the influxdb integration:
Is there a fix schedule when all metrics are pushed to VM (say 1min or 1sec or…) or is every metric only pushed if it has changed?
And if the former: is there a way to adjust the interval?
If I use prometheus integration I can set the interval for scraping myself.
A time-based push would lead to much redundancy (or does VM suppress doublettes internally?) but with pushing on-change only, I’d imagine future downsampling would be tricky?
How are people viewing the data in VM? Are you using Grafana + Prometheus data source or Grafana + Influx v1 data source? Or something else?
Grafana + prometheus data source. Grafana dashboard in HA (How to seamlessly add Grafana graphs to Home Assistant » The smarthome journey)
We have created an own datasource with some additional features for VictoriaMetrics GitHub - VictoriaMetrics/grafana-datasource: Grafana Plugin for VictoriaMetrics so you can use it with Grafana instead of Prometheus datasource.
Prefer using Home Assistant’s Prometheus integration rather than its InfluxDB one. VictoriaMetrics supports InfluxDB data sources but it really seems like it’s more designed for Prometheus-compatible ones.
I’m just using VictoriaMetrics’ web UI (VMUI) at the moment. Haven’t gotten around to setting up Grafana yet. VMUI is pretty good for ad-hoc queries. I was just using it today to check the daily peak output reached by my solar power system for the past six months:
max_over_time(homeassistant_sensor_unit_w{entity="sensor.envoy_current_power_production"}[24h])
I haven’t used InfluxDB for a long time, but I reduced the size of one of my DBs from 43GB to 15GB by switching from Prometheus to VictoriaMetrics. This particular DB was for server monitoring. 2 years of data, ~70k time series, with most metrics logged once per minute.
VictoriaMetrics (and Prometheus) are time series databases, which means they can only store numbers and how those numbers change over time, with tags per time series (entity name, etc). Boolean values (true/false, on/off) are always logged as 0 and 1. Do you have a use case where this isn’t sufficient?
First of all: I use InfluxDB v2.7 and I have never installed VictoriaMetrics.
I was thinking about VM to have faster queries (not that I need it…) and less space on disk, then I found that
  • VM cannot delete single points or arbitrary groups of points, only WHOLE metrics (it’s meant to be used for compliance with data protection laws…)
  • the query language PromQL used by VM is not that straighforward and intuitive (to me)
  • InfluxDB v2 with Flux queries can perform on its own QUITE some data processing without resorting to external scripts
At this point, I stopped being interested in VM.
And I was right, here a practical case.
I wanted to calculate the number of days in a year for which the hourly energy price spread is above a threshold, where the spread should be calculated on the Nth best spread (so, N=1 would be the very extremes, N=2 would be the spread between second highest and second lowest hourly price, amd so on). It’s useful to plan home battery systems (how many cycles can I perform a year? what is the average economical return per dis/charge cycle?).
I had to resort to some AI help (Gemini v2.5 Pro work quite well, whiel v2.5 flash ok but misses syntax, and Chatgpt is behind), but at the end I came up with:
import "influxdata/influxdb/schema"
import "array"
// Helper function to calculate the spread between the minimum of the top N
// and maximum of the bottom N values in a stream of tables.
// n: The number of top/bottom elements to consider.
// column: The column to operate on.
// tables: The stream of tables to process, passed implicitly.
calculateSpread = (n, column, tables=<-) => {
  // Calculate the minimum of the top N values. This returns a stream.
  top_mean_stream = tables
    |> top(n: n, columns: [column])
    |> min(column: column)
  // Calculate the max of the bottom N values. This also returns a stream.
  bottom_mean_stream = tables
    |> bottom(n: n, columns: [column])
    |> max(column: column)
  // Union the two streams (each containing one table/row) and calculate
  // the spread between the two values. This correctly returns a new stream
  // with the calculated spread as its value.
  return union(tables: [top_mean_stream, bottom_mean_stream])
    |> spread(column: column)
// function to calculate inverse histogram
// n: The number of top/bottom elements for calculateSpread.
// outputField: The string value to set for the "_field" column.
higherThanHistogram = (n, outputField, tables=<-) => {
  // Aggregate to daily spread using the calculateSpread function
  dailySpread = tables
    |> aggregateWindow(
      every: 1d,
      fn: (column, tables=<-) => calculateSpread(n: n, column: column, tables: tables)
  // Calculate the histogram (cumulative less than or equal to)
  cumulativeHistogram = dailySpread
    |> histogram(bins: linearBins(start: 0.0, width: 0.01, count: 30))
    |> set(key: "_field", value: outputField) // Use the outputField parameter here
    |> drop(columns: ["_start", "_stop"])
    // follows the cutting of the last "infinite bin" generated by "histogram"
    |> limit(n: 1000,offset: 1)
    |> tail(n: 1000,offset: 1)
    // Get the single record containing the maximum value from the histogram.
  // This results in a record object, not a stream.
  maxRecord = cumulativeHistogram
    |> group() // Group all rows to find the overall maximum
    |> max(column: "_value")
    |> findRecord(fn: (key) => true, idx: 0) // Extract the single record as an object
// Safely extract the float value from the record, defaulting to 0.0 if the histogram was empty.
  totalCount = if exists maxRecord._value then float(v: maxRecord._value) else 0.0
  // Calculate the "greater than" counts
  return cumulativeHistogram
    |> map(fn: (r) => ({
        r with
        _value: totalCount - r._value
// Main query starts here
data = from(bucket: "home_assistant/autogen")
  |> range(start: v.timeRangeStart, stop: v.timeRangeStop)
  |> filter(fn: (r) => r["_measurement"] == "€/kWh")
  |> filter(fn: (r) => r["entity_id"] == "current_electricity_market_price")
  |> filter(fn: (r) => r["_field"] == "value")
  |> aggregateWindow(every: 1h, fn: mean, createEmpty: false)
  |> drop(columns: ["domain", "entity_id", "source", "friendly_name"])
spread_1h = data
  |> higherThanHistogram(n:1, outputField: "spread_1h")
spread_2h = data
  |> higherThanHistogram(n:2, outputField: "spread_2h") // Corrected n and outputField
spread_3h = data
  |> higherThanHistogram(n:3, outputField: "spread_3h") // Corrected n and outputField
union(tables: [spread_1h, spread_2h, spread_3h])
|> pivot(rowKey: ["le"], columnKey: ["_field"], valueColumn: "_value")
|> rename(columns: {le: "Spread (€/kWh)"})
The result is:
This would be almost completely impossible if I were using VM, unless I wrote a Python script or equivalent, to be run offline (while Grafana allows me to change on the fly the time interval).
I asked Gemini V2.5 Pro:
For comparison, can you rewrite it (if possible) using PromQL, the query language of Prometheus, or a query language which VictoriaMetrics (which is based on Prometheus, with more capabilities) can understand?
The answer was:
It’s not possible to rewrite your entire Flux query into a single, equivalent PromQL or MetricsQL query.
The fundamental reason is that your Flux script performs a multi-stage analysis: it first calculates a derived value (the daily spread) and then performs a second level of aggregation on those results (the histogram). PromQL and MetricsQL are designed to perform one level of aggregation over a set of raw time series, not to re-process the results of a previous aggregation within the same query.
However, you can achieve the same goal by using the standard Prometheus/VictoriaMetrics approach, which combines server-side pre-aggregation (using recording rules) with client-side visualization.
The Conceptual Difference
  • Flux: Uses a data-flow model where you can pipe the results of one transformation into another, allowing for complex, multi-stage calculations entirely on the server within one script.
  • PromQL/MetricsQL: Uses a functional model where you select a vector of time series and apply aggregation functions to it. It is not designed for sequential, dependent calculations on derived data in a single query.
:gear: Step 1: Pre-Aggregating the Data with Recording Rules
The idiomatic way to handle this in Prometheus or VictoriaMetrics is to create recording rules. These rules run at a regular interval, calculate new metrics from existing ones, and save them back to the database. This makes the final querying fast and simple.
First, you would create a rule to calculate the hourly mean, similar to your first aggregateWindow.
Then, you’d create rules to calculate the daily spread for each value of n. For this, we’ll use MetricsQL functions, which are a superset of PromQL. The key is to use quantile_over_time to find the Nth highest and lowest values.
Here is an example of what these rules would look like in a YAML file:
(here come some YAML code…)
:bar_chart: Step 2: Querying and Visualizing in a Client (like Grafana)
Now that the complex calculations are done and stored, your work in the querying client (like Grafana) becomes incredibly simple. You cannot generate the inverse histogram directly in the query, but you can pull the raw spread values and let Grafana create the histogram for you.
  1. Query the Data: In your Grafana panel, you would query the pre-calculated spread metrics. To get all three on one graph, you could use a regex:Snippet di codice{__name__=~"electricity:price_spread_daily:n[1-3]"}This query fetches the daily spread values for n=1, n=2, and n=3.
  2. Use Grafana’s “Histogram” Visualization:
  • Change the panel visualization type to Histogram.
  • Grafana will take the values returned by the query and automatically bucket them, creating a histogram from the spread data.
  1. Create the Inverse Cumulative Histogram:
  • In Grafana’s “Transform” tab, you can add a transformation to calculate the cumulative count and then use another transformation (“Add field from calculation”) to compute Total - Cumulative.
  • Alternatively, many visualization options have a “Cumulative” display switch, and you can often configure it to show an inverse or “greater than” view.
:bulb: Summary of the Difference in Approach
Aspect Flux / InfluxDB PromQL / VictoriaMetrics
Complexity Handled in a single, complex server-side query. Split between server-side recording rules and client-side visualization.
Histogram Calculated on the server using histogram(). Calculated on the client (e.g., Grafana) from the pre-aggregated data.
“Nth Value” Done with top() and bottom() functions. Approximated very effectively with quantile_over_time().
Final Query The entire script you wrote. A very simple query like {__name__=~"electricity:price_spread_daily:n[1-3]"}.
So I would need to STORE INTERMEDIATE results in VM to be able to do what I needed. And notice that PromQL/MetricsQL is said to approximate the result for the spread.
So be VERY aware of this difference when evaluating VictoriaMetrics vs InfluxDB v2.
Concerning InfluxDB v1.8, Flux is (much?) less powerful and InfluxQL is ages behind, so no.
InfluxDB v3 Core (the free one) has no Flux anymore, I think, but offers SQL queries which can do that, but since I am afraid it will become paid or severely limited, I’m not going there.
For info, from Gemini v2.5 Pro, this is the SQL for InfluxDB v3 (untested!):
WITH
  -- Step 1: Filter the data and aggregate it into hourly means, just like the first part of the Flux query.
  hourly_means AS (
    SELECT
      date_bin('1 hour', "time") AS hourly_time,
      AVG(_value) AS hourly_mean
    FROM "€/kWh"
    WHERE
      "time" >= now() - interval '30 days' -- Example time range, adjust as needed
      AND entity_id = 'current_electricity_market_price'
      AND _field = 'value'
    GROUP BY hourly_time
  -- Step 2: For each hourly mean, determine its rank (1st, 2nd, 3rd, etc.) within its day,
  -- both ascending and descending. This is how we find the Nth highest/lowest values.
  daily_ranks AS (
    SELECT
      date_bin('1 day', hourly_time) AS day,
      hourly_mean,
      ROW_NUMBER() OVER(PARTITION BY date_bin('1 day', hourly_time) ORDER BY hourly_mean DESC) as rank_desc,
      ROW_NUMBER() OVER(PARTITION BY date_bin('1 day', hourly_time) ORDER BY hourly_mean ASC) as rank_asc
    FROM hourly_means
  -- Step 3: Group by day and pivot the ranked values to calculate the spread for n=1, 2, and 3.
  daily_spreads AS (
    SELECT
      day,
      -- Spread n=1 (max - min)
      (MAX(CASE WHEN rank_desc = 1 THEN hourly_mean END) - MAX(CASE WHEN rank_asc = 1 THEN hourly_mean END)) AS spread_1h,
      -- Spread n=2 (2nd highest - 2nd lowest)
      (MAX(CASE WHEN rank_desc = 2 THEN hourly_mean END) - MAX(CASE WHEN rank_asc = 2 THEN hourly_mean END)) AS spread_2h,
      -- Spread n=3 (3rd highest - 3rd lowest)
      (MAX(CASE WHEN rank_desc = 3 THEN hourly_mean END) - MAX(CASE WHEN rank_asc = 3 THEN hourly_mean END)) AS spread_3h
    FROM daily_ranks
    GROUP BY day
  -- Step 4: Generate the cumulative histogram for each of the three spread calculations.
  -- The HISTOGRAM table function is a powerful feature of InfluxDB v3 SQL.
  hist_1h AS (SELECT le, "count" FROM TABLE(HISTOGRAM(TABLE daily_spreads, 'spread_1h', 0.0, 0.01, 30))),
  hist_2h AS (SELECT le, "count" FROM TABLE(HISTOGRAM(TABLE daily_spreads, 'spread_2h', 0.0, 0.01, 30))),
  hist_3h AS (SELECT le, "count" FROM TABLE(HISTOGRAM(TABLE daily_spreads, 'spread_3h', 0.0, 0.01, 30))),
  -- Step 5: Invert each histogram. We calculate the total count for each series using a window function
  -- (MAX("count") OVER()) and subtract the cumulative count from it.
  inv_hist_1h AS (SELECT le, (MAX("count") OVER()) - "count" as value FROM hist_1h),
  inv_hist_2h AS (SELECT le, (MAX("count") OVER()) - "count" as value FROM hist_2h),
  inv_hist_3h AS (SELECT le, (MAX("count") OVER()) - "count" as value FROM hist_3h)
-- Step 6: Final SELECT. Join the three inverted histograms on their bin boundary ('le')
-- to pivot the data into the desired final shape.
SELECT
  inv_hist_1h.le,
  inv_hist_1h.value AS spread_1h,
  inv_hist_2h.value AS spread_2h,
  inv_hist_3h.value AS spread_3h
FROM inv_hist_1h
JOIN inv_hist_2h ON inv_hist_1h.le = inv_hist_2h.le
JOIN inv_hist_3h ON inv_hist_1h.le = inv_hist_3h.le
ORDER BY inv_hist_1h.le;
