Info API disabled..?
sorry i see a typo in the commands i gave.
there must always be a space after a : in yaml
  accessfile: /home/pi/.homeassistant/conf/dash_acces.log
problems in yaml cause that appdaemon doesnt start, so no dashboard.
sorry.
That made me open dashboard again. But I still cant turn on or off the lights there.
appdaemonerror.log is still empty
dash_acces.log is also empty
appdeamon.log says:
2018-02-22 00:41:28.161451 INFO AppDaemon Version 2.1.12 starting
2018-02-22 00:41:28.162271 INFO Configuration read from: /home/pi/.homeassistant/conf/appdaemon.yaml
2018-02-22 00:41:28.179947 WARNING Unable to connect to Home Assistant, retrying in 5 seconds
2018-02-22 00:41:33.429731 WARNING Unable to connect to Home Assistant, retrying in 5 seconds
2018-02-22 00:41:38.465798 WARNING Unable to connect to Home Assistant, retrying in 5 seconds
2018-02-22 00:41:43.497666 WARNING Unable to connect to Home Assistant, retrying in 5 seconds
2018-02-22 00:41:48.533911 WARNING Unable to connect to Home Assistant, retrying in 5 seconds
2018-02-22 00:41:53.563842 WARNING Unable to connect to Home Assistant, retrying in 5 seconds
2018-02-22 00:42:06.408187 WARNING Unable to connect to Home Assistant, retrying in 5 seconds
2018-02-22 00:42:11.459122 WARNING Unable to connect to Home Assistant, retrying in 5 seconds
2018-02-22 00:42:16.795329 INFO Starting Apps
2018-02-22 00:42:17.086165 INFO Got initial state
2018-02-22 00:42:17.087547 INFO App initialization complete
2018-02-22 00:42:17.088504 INFO Starting dashboard
2018-02-22 00:42:17.103354 INFO API is disabled
2018-02-22 00:42:17.382795 INFO Connected to Home Assistant 0.63.3
2018-02-22 00:42:44.455481 INFO Compiling dashboard ‘main’
2018-02-22 00:42:45.621634 INFO function [get_dashboard] finished in 1180 ms
2018-02-22 00:42:46.066624 INFO New dashboard connected: Main
2018-02-22 00:43:12.438886 INFO function [get_dashboard] finished in 108 ms
2018-02-22 00:43:12.456217 INFO Dashboard disconnected
2018-02-22 00:43:12.662350 INFO New dashboard connected: Main
sorry, then i dont know anymore.
Ok. Think ill try reinstalling HA from backup again. And then try one more time installing HADashboard.
Thank you verry much for the time you havve spent helping me :raising_hand_man:
