tom_l
March 15, 2023, 4:52am
21
Note however that your template will generate errors and possibly stop your automation actions if something other than a 1 or 2 is received (the else
case). A service must be supplied, it can not be null. You could put a script in there that just does a 1 second delay (scripts are services).
Though you might be better off with a choose action where you don’t have to supply an else case.
seanlow
(Sean)
March 15, 2023, 8:45am
22
Ah. Thank you for pointing that out. I will amend accordingly.
I was wondering, what would a good way be to control multiple entities from the single automation that detects a change in analog1?
For example, as I start to implement this properly, it would look more like:
service: >
# bedroom keypad button 1
{% if is_state('input_text.analog1', '2101') %}
media_player.bedroom.media_play
# bedroom keypad button 12
{% elif is_state('input_text.analog1', '2112') %}
media_player.bedroom.media_stop
# dining keypad button 1
{% if is_state('input_text.analog1', '2601') %}
media_player.dining.media_play
# dining keypad button 12
{% elif is_state('input_text.analog1', '2612') %}
media_player.dining.media_stop
{% else %}
script.delay1s
{% endif %}
I understand the above syntax won’t work, but it illustrates what I want to achieve, but I don’t quite know what the syntax would look like. It would be really nice if the above code does work though
tom_l
March 15, 2023, 8:58am
23
Your dining keypad if
statement needs to be an elif
statement and you have to be careful with comments in templates, put them in {# #} but other than that this will work:
service: >
{# bedroom keypad button 1 #}
{# bedroom keypad button 12 #}
{# dining keypad button 1 #}
{% elif is_state('input_text.analog1', '2601') %}
{# dining keypad button 12 #}
{% else %}
script.delay1s
{% endif %}
For your else case script you could replace the delay script with a more useful notification:
script:
invalid_key:
sequence:
- service: notify.notify # replace with your messaging service
message: "Invalid key number received: {{ states('input_text.analog1') }}"
w35l3y
(w35l3y)
March 15, 2023, 8:59am
24
Probably, it is using to_json
before setting the value.
You may use from_json
to get that value.
Something like
{{ states('input_text.analog1') | from_json == 1 }}
seanlow
(Sean)
March 15, 2023, 9:01am
25
Thanks. This particular issue is already solved.
seanlow
(Sean)
March 15, 2023, 9:07am
26
These sorts of calls don’t seem to work. I haven’t really spent much time trying to figure it out though.
The previous code works when this is included, but then I can’t target multiple players.
entity_id: media_player.dining
tom_l
March 15, 2023, 9:15am
27
Ah, ok. You have to template the service and the entity separately.
service: >
media_player.media_play
media_player.media_stop
{% else %}
script.delay1s
{% endif %}
entity_id: >
media_player.dining
media_player.dining
{% else %}
script.delay1s
{% endif %}
Now you really have to make sure the else case never happens with conditions. As the script service for the else case does not accept a target.
seanlow
(Sean)
March 15, 2023, 9:18am
28
Ahh, I see. I am really very very grateful for the pointers. I am not sure how long it would have taken for me to figure this out! YAML syntax is really strange for me to wrap my head around.
I will report back after I have some time to test this.
tom_l
March 15, 2023, 9:23am
29
You can use a condition like this:
condition:
condition: template
value_template: "{{ states('input_text.analog1') in ['2101', '2112', '2601', '2612'] }}"
seanlow
(Sean)
March 15, 2023, 12:30pm
30
Currently I have the script as:
alias: delay1s
sequence:
- service: notify.mobile_app_s
message: "KP Pressed, else event:: {{ states('input_text.analog1') }}"
mode: single
This works great whilst I am trying to program up the system, but in the end I just want to log the events in the Logbook. How can I modify that to log to the generic built-in logbook? I did play around with this a little but there is not much documentation on this from what I could find.
seanlow
(Sean)
March 15, 2023, 12:31pm
31
This works perfectly. Thank you so very much.
tom_l
March 15, 2023, 1:04pm
32
seanlow
(Sean)
March 15, 2023, 1:30pm
33
Got it, thank you
alias: delay1s
sequence:
- service: logbook.log
name: KP Else Event
mode: single
