Works great so far!
Hello, greetings to everyone, itās my first message. I am novice I have a raspberry 4 with a 240gb ssd to usb 3.0 port with raspberry pi Os desktop version with recommended softwareā¦ is it possible to do this installation on it? Tanks
Okā¦ working on raspberry pi 4 with ssd. Raspberry pi OS with recommended desktop software
Does this still work now? The last command (even the updated one from SKAL) doesnt work? Is it not possible anymore to install Home Assistant on Raspbian?
I reinstalled only 2 days ago. So it is still possible.
Did you follow the commands in this thread? Everything seemed to work except the final step where it says" This installer is no longer supported"
Follow this:
Awesome. That link and the steps worked. Thanks a lot!
The warning and suggestion regarding running āHome Assistant as a VM or run Home Assistant Core via a Docker containerā, is this something to worry or care about?
Works very well!!
