Install Home Assistant, Mosquitto broker and Node-Red on android
Hi, use lineage 18.1 on my LG g2 d800, so ove trying to install HASS via termux but… So ive try apply commands from forum, but nothing too, anyone who have alredy install hass contact me in telegram(link down) plz, i need your help
So i have the trouble with building cryptography, then the process stops automatically
There are instructions for python in termux wiki
https://wiki.termux.com/wiki/Python
First determine CPU architecture with uname -m.
Then depending on your cpu architecture run
export CARGO_BUILD_TARGET=armv7-linux-androideabi
or
export CARGO_BUILD_TARGET=aarch64-linux-android
Hope this helps.
How did you get HAOS run on Le Potato? Just bought it and can’t boot any other images than those offered by Libre Computer…
I didn’t use HAOS just debian image with HA core python installation. I don’t use Le Potato anymore because it became incompatible with newer versions of Home Assistant.
Home assistant 0.75.3
Installing some ancient version of HA in termux is a no go. Termux is a rolling release and, by default, it uses python 11. You can try to downgrade python 11 to python 10 and then try to install the latest version of HA. But it will probably break soon after you upgrade HA of termux. Try to find some other platform to run HA. Good luck.
Thank you. But somehow I was able to install home assistant.But I was unable to find addons store.Can u please help me with that.
only core version can be installed in termux, so no addons
