I had a few other issues so ended up deciding on a clean Ubuntu install and clean HAOS. Followed the steps at the top and all working now.
Hello, thank you for this guide. I followed this guide and read through all the comments, I had the same problem as Seventh Dima, nothing would show up in virsh net-list --all and I couldn’t find an IP for the KVM. I saw the post saying to turn off secure boot but unfortunately I don’t have that option.
Not really sure what else to do, I might just install Debian and go through the official installation instructions even though I’ve never used Debian.
If anyone has any other suggestions then hopefully they can help someone else who comes across this! Thank you
Like I said, I’m not really a network expert. But a few things to check:
- Are you using netplan to configure your network? The best way I have found to check this is to see if you have a
/run/network/ifstate
file with the name of your interface, in which case you are probably not (see this, and the comments). - What does your netplan file look like?
- What is the output of
ifconfig
If there’s nothing in the output from virsh net-list --all
, you have probably not successfully created a bridge, and everything after that (network-wise) won’t work.
For anyone who’s had their VM crash and not restart, I found my config in /etc/libvirt/qemu after following the directions in this thread.
Edit your hassos.xml.
Find:
<on_crash>destroy</on_crash>
And replace it with:
<on_crash>restart</on_crash>
Now if your HASSOS dies in the middle of the night you won’t wake up to a dead automation system.
Haven’t figured out what caused it yet, but putting this band-aid on took some digging so I thought I’d share it.
You can also edit the nearby line to make it start on reboot, but I had already done that with a CLI command.
I had not thought about that scenario.
I was curious if this could also be done using virsh… turns out you can (My domain name is hassio
, so substitute yours if different):
virsh set-lifecycle-action hassio crash restart --config
virsh set-lifecycle-action hassio crash restart --live
The first one changes the domain’s xml file for you, the second one presumably acts on the Domain/VM while its running. There are also some core-dump options too (not shown).
@Aephir First things first, thank you for putting together this guide. I’ve outgrown my RPi4 and will give try following your step-by-step instructions on my recently purchased mini pc.
I noticed that you mention in an earlier post that you have upgraded to Ubuntu 22.04. Have you had any success getting this to work on Ubuntu server 22.04 LTS?
Sort of. It works, but I didn’t install on 22.04, just upgraded from 20.04 after installing, so can’t say if there would be changes for the actual install.
But please let me know how it works if you try!
@Aephir thanks so much for this guide!
I installed on Ubuntu 22.04, but I had to add
--osinfo detect=on,require=off
to bypass the os-variant
requirement.
Additionally, you should add that the qcow2 file should either be in the same directory (var/lib/libvirt/images/hassos-vm
) or else reference the full path in the --disk
arg.
@Aephir I followed your guide and was able to install HAOS in Ubuntu server 22.04 LTS using kvm. Once I got it up and running, I simply restored a full backup of my RPi4 HAOS. One caveat, I haven’t moved my zwave stick over yet. I will do that next.
Below are some notes from my experience that may be of interest to others.
- I am running this VM on a Beelink EQ12 which has two LAN ports that I want to pass through to the VM. So I used a slightly different
/etc/netplan/00-installer-config.yaml
file. See below.
# This is the network config written by 'subiquity'
network:
ethernets:
enp1s0:
dhcp4: true
enp2s0:
dhcp4: false
version: 2
bridges:
br0:
dhcp4: true
interfaces:
- enp1s0
parameters:
stp: true
br1:
dhcp4: false
interfaces:
- enp2s0
addresses:
- 192.168.50.10/24
nameservers:
addresses: [192.168.1.1]
parameters:
stp: true
- When I applied the netplan above, Ubuntu 22.04 assigned a new mac address to the bridge
br0
. This is really strange because I expected it to be the same as the mac address forenp1s0
. After some googling around I found that this issue is associated with Ubuntu 22.04 but no one seems to know exactly why. In any event, the original mac address can be cloned on the bridge by doing the following.
Change themacaddresspolicy
in/usr/lib/systemd/network/99-default.link
frompersistent
tonone
This is important because I want my router to assign a static ip address based on the mac address ofenp1s0
. - To install the VM, I used the following command. Note that I manually assign mac addresses to the VM’s LAN ports. Again, this is because I want to be able to assign static ip addresses using mac addresses. Also, I followed the approach suggested by @poiromaniax and used
virt-install --import --name haos --description "Home Assistant OS" --osinfo detect=on,require=off --ram=3072 --vcpus=2 --disk /var/lib/libvirt/images/haos-vm/haos_ova-10.3.qcow2,bus=virtio --network bridge=br0,model=virtio,mac=52:54:00:B9:7A:01 --network bridge=br1,model=virtio,mac=52:54:00:B9:7A:02 --graphics none --noautoconsole --boot uefi
I followed the instructions provided by @brady, namely to create the
/etc/docker/daemon.json
file and restart docker. But when I went to restart docker, I got a message saying that the service didn’t exist:Failed to restart docker.service: Unit docker.service not found.
. It didn’t seem to interfere with anything I was doing. -
I found that I needed to install the
virtinst
package.
Thanks @Cold-Lemonade , @poiromaniax . I have added a few comments and changes as per your suggestions.
OS: Ubuntu 23.04 Server
Hardware:
- Beelink SEi12 Pro
- Zooz z-wave stick 700
I followed the updated tutorial step by step and got it working almost effortlessly. I did bump into problems in step 2.1 as I’m not using docker and have no idea what that step is supposed to do. I skipped it and all is well. Thank you all, especially @Aephir.
I did notice that XRDP completely broke after setting up the network bridge. I modified the netplan config as follows and all is well again.
network:
ethernets:
enp3s0:
dhcp4: true
version: 2
bridges:
br0:
dhcp4: yes
interfaces:
- enp3s0
parameters:
stp: true
routes:
- to: 0.0.0.0/0
via: 192.168.1.1 # Your IP Gateway, run: 'ip route | grep default'
@Aephir forgot to also mention (and because I totally borked my machine I had to reinstall)
Ubuntu 22.04 (havent checked earlier releases), also need to install virt-manager
package. May want to add that into your installation command in step 1.1
Also, am I the only one that has: “start job is running for Wait for Network” on startup
For docker, editing the docker.service
worked but not creating the etc/docker/daemon.json
I typically don’t look during startup (everything running headless, I only SSH into the machine), but I do seem to remember this from way back when I had a monitor connected. I think it’s just that your network startup is slower than whatever start job
that is set to require/wait for network. Nothing to be alarmed about, it just (as far as I know) pauses the start job until network is up and running.
If you don’t mind me asking, what does not work if virt-manager
package is not installed? My thought is that virt-manager is not needed for a setup that only uses cli (virsh/virt-install
). As a note, I do use virt-manager and a desktop, so just curious.
@wmaker
When I tried virt-install
without installing extras, it came back with Command Not Found
After googling around, I learned that virt-manager
is the way to install this
OK I see, thanks.
I’m looking at some notes I took during my installation, and virt-manager
installs virtinst
, and virt-viewer
, so I think in theory instead of installing virt-manger
one can simply install virtinst
@Aephir After my success getting this work on Ubuntu 22.04 LTS Server, I decided to install Ubuntu 23.04 Server on my mini pc so I had to start all over. Good news, I got it working by following your steps. Like @luis-godinez, I skipped Step 2.1 and didn’t have any problems. Also, like @wmaker, I had to install virtinst
In case anyone else tries to do this on Ubuntu 23.04 Server, I should note that there is a weird bug in the 00-installer-config.yaml
used for configuring netplan
on this version of Ubuntu. To address this bug, I had to change the permissions for this file using chmod 700
. Also, their earlier change to the MACAddressPolicy
that I described in an earlier post will not prevent the kernel from assigning a different mac address to the bridge. I had to manually assign the physical ethernet interface’s mac address to the bridge in the 00-installer-config.yaml
While everything worked without issue, when I enabled by ufw
firewall on the host computer, it completely cut off the virtual machine running HAOS. Does anyone have any insight into what ufw
rules I need to add to allow the vm to access the network? With ufw
enabled, my router cannot even assign an ip address to the vm because it cannot see it.
Has anyone got this working with ufw
Hope you don’t mind me asking (I’m trying to understand your networking config) but do I have this correct, that you are trying to get your Ethernet interface (enp1s0) and the Bridge interface (br0, which is using enp1s0) to have the same MAC? And you are trying to have an IP address assigned by DHCP to both interfaces? And you want DHCP to use the MAC to assign an IP address? Wouldn’t this result in two interfaces with the same IP address?
Hi @wmaker.
I want the host and the vm to have separate ip addresses and that is currently working.
Both ip addresses are assigned using dhcp
by the router. When I first install the vm, my virsh
command manually assigns the vm a different mac address for its virtual ethernet interface (vnet0) than the one I manually assigned the bridge (br0) in netplan
. Because they have different mac addresses, the router assigns them different ip addresses (or so I surmise given my very basic understanding of networking). The context for all of this is that Frigate NVR is running in a container on the host and HAOS running in a vm on the host. I want to be able to access these applications through separate ip address.
I have it set up and working with two separate ip addresses. The problem is that when I enable ufw
on the host, it blocks the vm from accessing the network and so HA is cut off from everything. My host’s ufw
rules are very restrictive so I am trying to figure out what rules to add to allow the vm access to the network via vnet0
I hope this explanation makes better sense.
I think I have found a solution to the problem of ufw
blocking the vm running HAOS. I assigned a static ip address to the virtual ethernet interface (vnet0) in my router using the mac address that I manually assigned when I created the vm. Then I set up forwarding rules in /etc/ufw/before.rules
. For more details, see this:
