Install software on HAOS
Thanks! This would actually be the best solution! I just need to modify it to change shutdown to reboot; I also do not need all of those statistics. Lemme see what I can do.
[Edit: Looks like line 187 is key here.]
Thanks again!
Just to clear up any confusion, when installing/running Home Assistant using a Docker Containerā€¦the Container is running Home Assistant Core :slight_smile: .
Thank you! I think this fact should be posted somewhat more conspicuously on the corresponding page.
