I open on Android aplication Home Assisten.
Look first image.
I click to “check for uodates”.
And I see look on image two.
The Android app Home Assistant (https://play.google.com/store/apps/details?id=io.homeassistant.companion.android) is for connecting your phone to your existing install of Home Assistant.
It needs you to have done that first.
It also needs a relatively current version of Android and WebView (https://companion.home-assistant.io/docs/getting_started#system-requirements)
You’ve told us nothing about your phone, so I’m going to have to guess that it’s ancient and horribly outdated.
After turn off vpn I can log in to panel using browser.
I can’t find option to add smart plugs connected to ewelink.
That’s probably what you want
That is answer for question from first posr:
Blockquote
Yes, you can use Home Assistant on Ubuntu!
Home Assistant offers two main installation options for Linux:
Home Assistant Core and Home Assistant OS.
While Home Assistant OS is a complete operating system designed specifically for Home Assistant, Home Assistant Core can be installed on top of an existing Linux distribution like Ubuntu.
### Installing Home Assistant Core on Ubuntu:
1. Update Your System:
Ensure your Ubuntu system is up to date:
sudo apt update && sudo apt upgrade
2. Install Dependencies:
Install the necessary dependencies:
sudo apt install -y python3.12 python3.12-dev python3.12-venv bluez libffi-dev libssl-dev libjpeg-dev zlib1g-dev autoconf build-essential libopenjp2-7 libtiff5* libturbojpeg0-dev tzdata ffmpeg liblapack3 liblapack-dev libatlas-base-dev
3. Create a Home Assistant User:
Create a dedicated user for Home Assistant:
sudo useradd -rm homeassistant
sudo chsh -s /bin/homeassistant
sudo usermod -aG dialout homeassistant
4. Set Up Home Assistant Directory:
Create a directory for Home Assistant data and assign ownership:
sudo mkdir /srv/homeassistant
sudo chown homeassistant:homeassistant /srv/homeassistant
5. Switch to Home Assistant User:
Switch to the newly created Home Assistant user:
sudo -u homeassistant -H -s
6. Initialize Virtual Environment:
Create and activate a Python virtual environment:
cd /srv/homeassistant
python3.12 -m venv .
source bin/activate
7. Install Home Assistant:
Install Home Assistant using pip:
pip3 install homeassistant
8. Start Home Assistant:
hass
### Accessing Home Assistant:
Once Home Assistant is running, you can access it by navigating to
http://<your-server-ip>:8123
in your web browser.
Would you like more detailed instructions or have any specific questions about the setup?
https://community.home-assistant.io/t/guide-installing-home-assistant-core-on-ubuntu-22-04/608224?citationMarker= "1"!
https://community.home-assistant.io/t/guide-installing-home-assistant-core-on-ubuntu-22-04/608224?citationMarker= "1".
sudo useradd -rm homeassistant sudo chsh -s /bin/homeassistant sudo usermod -aG dialout homeassistant
sudo mkdir /srv/homeassistant sudo chown homeassistant:homeassistant /srv/homeassistant
cd /srv/homeassistant python3.12 -m venv . source bin/activate
hass
CoPilot
> Blockquote
