Installation of Home Assistant on your FreeNAS
The answer wasn’t facetious … but if you want to take it that way, have at it.
If your using the community plugin you can do this
iocage console $JAIL_NAME
# press 0 to exit menu
pkg install -y python39 py39-sqlite3
sysrc homeassistant_python=/usr/local/bin/python3.9
service homeassistant reinstall homeassistant
If you installed HA manually in a jail you can follow this post
I also updated the OP for Python 3.9
Thanks Troy, very useful for confirmation. Have run this and it all works great.
Me too. All works a treat.
Hi all - trying this on a fresh install of Freebsd 13.2-RELEASE in a jail, and it’s failing on installing PyYAML-6.0. Has anyone run this successfully recently?
Collecting pyyaml==6.0 (from homeassistant)
  Downloading PyYAML-6.0.tar.gz (124 kB)
     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 125.0/125.0 kB 9.1 MB/s eta 0:00:00
  Installing build dependencies ... done
  Getting requirements to build wheel ... error
  error: subprocess-exited-with-error
  Γ— Getting requirements to build wheel did not run successfully.
  β”‚ exit code: 1
  ╰─> [48 lines of output]
      running egg_info
      writing lib/PyYAML.egg-info/PKG-INFO
      writing dependency_links to lib/PyYAML.egg-info/dependency_links.txt
      writing top-level names to lib/PyYAML.egg-info/top_level.txt
        File "/srv/homeassistant/lib/python3.9/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 353, in <module>
          main()
        File "/srv/homeassistant/lib/python3.9/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 335, in main
          json_out['return_val'] = hook(**hook_input['kwargs'])
        File "/srv/homeassistant/lib/python3.9/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 118, in get_requires_for_build_wheel
          return hook(config_settings)
        File "/tmp/pip-build-env-n5r9wj56/overlay/lib/python3.9/site-packages/setuptools/build_meta.py", line 341, in get_requires_for_build_wheel
          return self._get_build_requires(config_settings, requirements=['wheel'])
        File "/tmp/pip-build-env-n5r9wj56/overlay/lib/python3.9/site-packages/setuptools/build_meta.py", line 323, in _get_build_requires
          self.run_setup()
        File "/tmp/pip-build-env-n5r9wj56/overlay/lib/python3.9/site-packages/setuptools/build_meta.py", line 338, in run_setup
          exec(code, locals())
        File "<string>", line 288, in <module>
        File "/tmp/pip-build-env-n5r9wj56/overlay/lib/python3.9/site-packages/setuptools/__init__.py", line 107, in setup
          return distutils.core.setup(**attrs)
        File "/tmp/pip-build-env-n5r9wj56/overlay/lib/python3.9/site-packages/setuptools/_distutils/core.py", line 185, in setup
          return run_commands(dist)
        File "/tmp/pip-build-env-n5r9wj56/overlay/lib/python3.9/site-packages/setuptools/_distutils/core.py", line 201, in run_commands
          dist.run_commands()
        File "/tmp/pip-build-env-n5r9wj56/overlay/lib/python3.9/site-packages/setuptools/_distutils/dist.py", line 969, in run_commands
          self.run_command(cmd)
        File "/tmp/pip-build-env-n5r9wj56/overlay/lib/python3.9/site-packages/setuptools/dist.py", line 1234, in run_command
          super().run_command(command)
        File "/tmp/pip-build-env-n5r9wj56/overlay/lib/python3.9/site-packages/setuptools/_distutils/dist.py", line 988, in run_command
          cmd_obj.run()
        File "/tmp/pip-build-env-n5r9wj56/overlay/lib/python3.9/site-packages/setuptools/command/egg_info.py", line 314, in run
          self.find_sources()
        File "/tmp/pip-build-env-n5r9wj56/overlay/lib/python3.9/site-packages/setuptools/command/egg_info.py", line 322, in find_sources
          mm.run()
        File "/tmp/pip-build-env-n5r9wj56/overlay/lib/python3.9/site-packages/setuptools/command/egg_info.py", line 551, in run
          self.add_defaults()
        File "/tmp/pip-build-env-n5r9wj56/overlay/lib/python3.9/site-packages/setuptools/command/egg_info.py", line 589, in add_defaults
          sdist.add_defaults(self)
        File "/tmp/pip-build-env-n5r9wj56/overlay/lib/python3.9/site-packages/setuptools/command/sdist.py", line 104, in add_defaults
          super().add_defaults()
        File "/tmp/pip-build-env-n5r9wj56/overlay/lib/python3.9/site-packages/setuptools/_distutils/command/sdist.py", line 251, in add_defaults
          self._add_defaults_ext()
        File "/tmp/pip-build-env-n5r9wj56/overlay/lib/python3.9/site-packages/setuptools/_distutils/command/sdist.py", line 336, in _add_defaults_ext
          self.filelist.extend(build_ext.get_source_files())
        File "<string>", line 204, in get_source_files
        File "/tmp/pip-build-env-n5r9wj56/overlay/lib/python3.9/site-packages/setuptools/_distutils/cmd.py", line 107, in __getattr__
          raise AttributeError(attr)
      AttributeError: cython_sources
      [end of output]
  note: This error originates from a subprocess, and is likely not a problem with pip.
β”‚ exit code: 1
╰─> See above for output.
I can’t really help with this error in particular but it looks like you’re using Python 3.9 which has not been supported for some time now. As of Home Assistant 2023.8, you will need Python 3.11.
This was documented in 2023.6 Breaking Changes
Python
All Home Assistant versions, of which the Home Assistant project manages the Python version for you, have been upgraded to Python 3.11. This affects the following installation types:
  • Home Assistant Operating System
  • Home Assistant Container
  • Home Assistant Supervised
This might affect you when using custom integrations, as those must be compatible with Python 3.11.
Furthermore, as of this release, Python 3.10 is deprecated, and support will be removed in Home Assistant 2023.8. This only affects you if you are running Home Assistant Core installation type in your own Python virtual environment. Please update your Python version to Python 3.11.
If you run Home Assistant OS, Home Assistant Container, or Home Assistant Supervised, we have taken care of this for you; you will be using Python 3.11 automatically on upgrade.
Maybe upgrading to a supported version of Python will help. Keep in mind, with this installation method you’ll need to upgrade Python and rebuild your virtual environment every year.
If you really want to run Home Assistant on TrueNAS, you can use this script I created a while back. It is still using python3.10 because 3.11 is having issue with one of the packages (PyTurboJPEG) or something.
