If you’ve got to that screen it’s looking good. The 20 min message is wildly optimistic - some people posting here have reported hours, even overnight. Be patient. Fortunately you only have to do it once.
Edit: The post you refer to is quite old - got to watch out for that.
Hmm. I put haos_rpi3-10.4img.xz with etcher on the SD card and with this image the screen stays black, nothing happening at all (At least as terminal outoput) but IP is also not reachable… Is this the wrong image or do I use etcher (however) in a unpropper way…
The Link that is provided there is just the 64 bit version (Which I also tried but again screen stays black). I don’t know what I am doing wrong but somehow it seems it was not meant to be…
Ok, I was able to install the lite-32bit-verwsion from Raspi-Imager, so I can logon to SSH now, but for my usecase I would need the HACS-store so a docker environment does not really work, right?
Well I’m stuck again! The Raspian Ubuntu comes with Python 3.9 with is not good enough for HASS to run.
So the attempt to compile Python 3.11 on the Zero 2 W resulted in an abort because the device ran out of memory…
Strange. Flashed this image to an SD this morning, since I don’t find my mini-hdmi to hdmi-adapter I set a fixed IP-adress in dietpi.txt, plugged an USB to Ethernet adapter in, plugged the SD card in and started the pi zero w2. Then I went shopping When I came back I could ping the pi. Logged in via putty.
Installing supervised now.
Ehm I did something strange /s, I tried the two other images dietpie offers. And after ARMv7 raised the init kill error and ARMv8 did not show anything at all I tried ARMv6 and this seems to work.
