Installer for QNAP QTS series
Download the latest release at https://github.com/sanmibuh/qnap-homeassistant/releases and install it with QNAP App Center
Thanks, I tried that, but couldnā€™t figure out how to configure it.
Ended up doing the Docker install.
The configuration is the same way on my build and on docker. See home-assistant documentation for more info.
Note that docker version is preferred if your qnap support it.
Thanks, Iā€™m running it in the Container Station, I think thatā€™s a more simple way for management purposes.
I successfully installed HA on my tvs-682 to container station the other day, but I havenā€™t tried connecting a zwave usb antenna yet. Any advice on which one to get?
Also, Iā€™ll be getting the monoprice six zone amp/controller for whole home audio. Its the same/similar to the Russound CAA66 and supports rnet over rs232. Any suggestions on a compatible usb to rs232 adapter?
Hi Johnny,
How did you get the zwave working? Iā€™m stuck trying to get a zooz zst39 working.
